Dash brake light
Old May 31, 2020 | 08:04 PM
05 Wreck's Avatar
05 Wreck
Default Dash brake light
After bleeding my brakes the brake light is on my dash. I have bled the brakes in the same manor 3-4 times and this is the first time the light has remained lit after start up. Any input appreciated.
Old Jun 1, 2020 | 08:27 AM
Dano523's Avatar
Dano523
When you pull the DTC code, is it point you to the fluid level sensor in the tank as the problem, or the EBCM instead.
Hence with dash light light up, any scanner should be able to pull the code number to post it here.
Old Jun 1, 2020 | 08:33 AM
05 Wreck's Avatar
05 Wreck
Thanks. I haven't checked for a code with my scanner as all the searches I've found said you had to have a Tech 2?
Old Jun 1, 2020 | 08:35 AM
Dano523's Avatar
Dano523
Tech II is need to get down to the body level on some things/pull some history codes, but if your are getting a dash light, then basic candi scanner will pull that code.
Old Jun 7, 2020 | 12:40 PM
05 Wreck's Avatar
05 Wreck
Dano,
No codes pulled with scanner. I'm going to investigate the hand brake switch next?
To Dash brake light
