Finding RPO codes online from my VIN
I’m changing my BCM. Don’t have the original glove box door with the RPO codes sticker. Where can I find my cars’ codes using my VIN online? 2009 C6 base.
Bob
Bob
There is no online resource for this information. Your best bet is to contact the National Corvette Museum and purchase the "build sheet" which includes the RPO codes for your vehicle
Received 2,683 Likes
2018 C6 of Year Finalist
^ Or get a "Vehicle Build Information" page printed out from GMVIS/Workbench at your local GM dealer for free.
Deven Davidoff (06-17-2020)
Don't need it, since when you go to TDS flash, TDS will pull the vin number to start with, and flash in what will be needed in the BCM. Also, when you go to flash the BCM, make sure to select replace and program, so TDS will hand shake the GM security code across the modules so they are hand shaking correctly as well. If you select just re-flash alone like a firmware update, TDS will not do the hand shake security code programming instead.
Also, once flashed, go in with a Tech II in BCM set up, just to make sure that what items that are in the car, are checked in the RPO list.
Received 8,801 Likes
Not sure if this is what you’re looking for but I’ve printed off the report for each of my 3 vehicles & it matches the window stickers I have.
https://www.compnine.com/vid.php
