Radio Sound Fluctuates
My 2008 C6 Coupe is exhibiting a weird issue with the sound system (factory Bose). The speakers, I think mostly driver’s door, will lose bass altogether and the sound is very “tinny”. This is when the factory radio is playing. Then, it will revert to normal, full sound. If I play a CD, I don’t get this bass-on/bass-off phenomenon. So, do I focus on the driver’s door speaker or is the radio head unit failing to send a proper signal or the speakers?
Could be either, since the Bose amp sends a signal to the thumper speakers amp in the door.
With the thumper going in and out, either a thermal problem that is shutting down the channel to the amp itself, or just a intermediate wiring/connector problem instead (could be either signal, or just power to the thumper amp isntead). Hell, if the thumper has seen a hard life, may just be a problem in the speaker portion itself.
Received 2,522 Likes
I’ve owned four Corvettes - C4, C5, C7, and now a C6 - and the head unit in the C6 is by far the worst I’ve ever heard. I replaced mine with a Sony and it sounds great now.
I've considered replacing the head unit for various reasons. However, I have a HUD system and from what I've read, I think switching the head unit to an aftermarket one loses my HUD connectivity, right?
I replaced my stock radio a few months ago. Since then I started having battery drain issues and lately volume fluctuations. I reinstalled my stock radio and both problems went away. I'm sure the PAC rp5-gm11 radio interface is the reason for problems. We're taking a long trip soon and I don't want any problems with aftermarket stuff, so I'm sticking with stock for now. I know that dosen't answer your question, but read up on the PAC interface if you're thinking of going aftermarket. I know PAC has good customer support so I'll be giving them a call.
