Whats everyone use on their paint? Here's mine
These post come up regularly and I am one that believes in care care, but to be honest, every picture looks the same. Pictures don't always show you the real finish. I have seen cars that at 5 feet look great and some even closer, but once you stop and really look at the actual finish from different angles, you will then see the swirls and small scratches if the owner has not don't a complete paint correction. I have used nothing but Adams on my Corvette's for the past15 or so years. It really comes down to what you are happy with as far as ease of use and durability.
As for the ceramic, I see no difference in the over all shine. The nice thing about ceramic is how the water will run off the surface and it stay cleaner longer as the normal dirt and dust does not stick to the surface. It is also a great protection from bird droppings. The big difference is first the prep. I ceramic should always be applied only after a complete paint correction and that is because if there are any swirls or scratched, and the ceramic is applied it is extremely difficult to strip the ceramic off to correct those areas. Below are two pictures of my '07 Monterey Red Metallic first with wax and the second with ceramic.
Adams Patriot Paste Wax
Adams Ceramic Coating
The following 2 users liked this post by BWF07:
Jamie Lennartson (08-17-2020),
Kr65 (09-26-2020)
Not much use on paint. Car doesn’t see rain. Normally just use Meguiars Quik detailer with a brand new microfiber about every 3 weeks. If I hit a few bugs on the front. I clean them off after every drive. I do wash tires and rims about every 90 days, with no greasy tire spray included. Tire spray is pretty much a dust magnet anyway. For wax, I use Meguiars NXT. Z always looks outstanding.
Black cars are a different animal.. So glad I didn’t do black on this one. They look amazing when clean but I do have a disorder. Silver helps that disorder.
The following 3 users liked this post by HiVolts:
and dark cars show everything.
I had car under very bright led light and that light takes no prisoners, shows everything, but in the sun you cannot see it.
my photos are 108 megapixel but some I have to compress because to large for corvette forum.
The secret isn't the products you use, it's the time you spend. Products can help, but from brand to brand it's mostly preference.
After decontamination (Clay bar, Iron X, IP Bath)
Goes:
Cutting
Correction
Polish
Sealant
Ceramic Coat (If wanted)
Wax
Gloss Coat
Goes:
Cutting
Correction
Polish
Sealant
Wax
Gloss Coat
The following 3 users liked this post by Function Racer:
Received 2,504 Likes
I get my cars ceramic coated by GlassLIfe Atlanta. This is my 09 after going through two downpours while on the road. You could see some dirt on the back of the car around the taillights, but everything else rolled right off. Brake dust doesn't even stick to the wheels. The only thing I hate is the tire shine sticks - you can see it on the fender behind the front tire. A quick walk around with an old T-shirt takes care of that.
I had a 15 Torch Red C7 coated there and when I was driving it and the sun hit the driver's side fender just right it would blind me. I had to drive with my right hand while holding up my left hand to block the glare. Ceramic coating has reduced the time I spend on the exterior of the car a ton.
I just love Angel Wax products.... Perfect Polish then some Angel Wax Enigma...
