c6 seats
Race Car Tech
Welcome to the forum. Is it possible that the switch is getting stuck on the side of your seat?
Possibility you may have an issue with your driver seat and telescoping module.Had same issue with my 05 more than 10 years ago so difficult to remember what the warranty fix was at the dealer.Seems was an issue concerning d.s module and telescoping steering module.I have a new d.s. module sitting on the shelf here and didn't install it as I preferred the auto telescoping wheel feature not to activate on entry and exit so that module harness under seat would not be moved constantly causing other issue's.I keep all my invoice's for work performed but that one seems to be missing in action
Race Car Tech
You can check under the seat to be sure that one of the wires is not bare and touching the under seat support wires.
Then go from there.
Good Luck
Then go from there.
Good Luck
If so, it's possible that plastic cover on the bottom/side of the seat was reinstalled incorrectly.
If installed incorrectly the plastic cover can put pressure on the seat adjustment switch which can cause the problem you have.
