Cracked windshield
Received 8,791 Likes
Any glass speciality shop, i.e. Safelite, should be able to do it. My local Chevy dealer shows the OEM windshields to be about $400 or so yet in almost every thread I see on the topic people are paying $700-1,200 so I don’t know. Some say it’s for the HUD-specific windshield but that also shows $400ish on the dealer’s website
We just had to have the windshield on my wife’s Outlander replaced & from the same guy who replaced it last year the price was double. He said he’s getting raked over the coals from the suppliers “due to covid”. Same thing on a single pane window on my house. Same company that replaced a much larger window for us before was over double on this window - I got the same excuse “prices have gone up due to covid”.
John K MD (09-23-2020)
Just make sure you specify that your car has the heads up display, to get the correct windshield.
I've used Safelite for all 3 of my windshield replacements too. I highly recommend them. Great customer service, and a great warranty. I had them fill a big chip, found that the repair was extremely visible once it had cured because it ended up cracking the windshield slightly around the chip, and they replaced the windshield under warranty as a result.
Just a FYI, but safelite's parent company is the ones that makes the Glass for GM to begin with (they bought the company).
At one time, you could get the windshields with the GM part of the labeling removed since they had a over run of them, for a hell of discount direct since they did not have to kick money back to GM for the windshield being labeled GM.
Received 1,596 Likes
Safelite has replaced the windshield twice in my GS, with excellent service both times.
marinablu67 (09-23-2020)
You do not actually "have" to buy the HUD specific windshield. The difference between the standard windshield and the HUD windshield is a layer of special material inside the glass where the HUD is displayed. The same technique used for aircraft to minimize glare, distortion, and maximize clarity, which is really cool! but a little overkill for your car in my opinion (especially for the price of this other one). I understand wanting to keep everything OEM/"as it should be", but it's a windshield. Plus if you drive a lot like I do, it can save you quite a lot of $$.
I drive my car a lot (~20K a year) and finally had a rock pop up and crack mine on the way to AZ. The best price for the HUD windshield (at the time) was ~$800 + install. I decided to shop around and found a local windshield shop and where the installer told me about this little gem! There is an aftermarket windshield for C6s by a company called Pilkington Solar. She apparently has replaced quite a few Vette windshields and was insistent the HUD will look nearly identical. The cost would be $280 installed. For the price, I decided to give it a shot. Made an appointment for later that week and she had it done in an hour. I'm 26 with perfect eyesight, and If I'm looking really hard and had to point out the difference, I'd say it's maybe 5% less bright/green and 3% wider. That's it. The display is perfectly clear and I never would have known the difference if I didn't have another C6 (my dads) to compare side-by-side with. Definitely worth looking into if you want to save some money or drive in an area where you're more at risk of getting chipped. Hell, you could replace it 3 times before you paid for the HUD glass. Hope this helps!
Safelite's parent does not make glass . Our parent is Belron International and we are the largest auto glass repair and replacement company in the world
What we do is, along with being the largest buyer of OEM branded glass we also buy the OE equivalent which is the OEM manufactured part but with no GM logo and we have never sold a AP Tecnoglass with the GM logos blasted off
And while there were other oem manufacturers that would blast the oem logo off, AP Tech and the corvette part number was NEVER one of the these parts as the corvette and its low production numbers never experienced an overrun
With the current production shortages caused by Covid you will be hard pressed to find an OEM or an OE branded glass as the manufacturers are concentrating on new car production
And in response to the other post , yes on a C6 a NON HUD windshield will reflect the HUD image just fine and i can guarantee that you will not be able to tell the difference . If anyone would like a detailed explanation as to why the C6 is a unicorn in this respect, send me a PM and I will explain
Dave
PS Pat thank you for your business
Patsgarage (09-23-2020)
I’ll agree that a non-HUD windshield will reflect the HUD image just fine, I will disagree that those with good eyesight won’t be able to tell the difference. I installed a HUD in my 1LT Grand Sport (obviously non-HUD windshield) and my 3LZ Z06 has the HUD and HUD windshield. The image in the Z06 is noticeably crisper than in the GS. After looking at the HUD in the Z, the image in the GS has just a slight blur to it. Granted both cars have OEM windshields.
It has to do with where the image is projected on the glass, the curvature and the angle of the installation .
Now some cars do need a HUD interlayer otherwise a ghosting of the image will occur but with a C6 all the stars line up where you will see a perfect image . If your image is not crisp between two C6 's its not the glass ... its the difference in tollerences of the HUD projection UNIT
Read about what a HUD interlayer does here to eliminate a ghosting because the image is being projected on both layers if glass , basicly is a prism that corrects the second image enough that it lines up with the first
https://www.s-lecfilm.com/eng/produc...hud/index.html
Dave
For other states Full Glass coverage for a car that is 10 to 15 years old is expensive and not everyone carries full coverage .
Dave
I looked into it originally. I have full coverage out here in CA and my insurance (USAA) does have a glass replacement claim that you can fill out, but it only covers a windshield repair, not a replacement. At least not without paying your comprehensive deductible at that point it would've cost me more than her shop did and I would have had to deal with my insurance company. No thanks
