2010 corvette wont start even new fob & engine batt. Help
Good day to all …I replaced my shifter cable, now my vette wont start , replaced fob batteries and main battery batteries..car is in park still wont turn over , I still have to replace a shattered passenger window …..will that cause it not to start due to security system , if not what could it be ?
Received 1,789 Likes
Just a guess, but if it was starting OK before and you didn't adjust the new shifter cable properly such that the car doesn't think it's in Park, then it won't start.
BigDean (11-23-2020)
1. Engine Turns over, does not start?
2. Engine does not turn over?
I agree on this comment, adjust the shifter cable to actually get the transmission in park, then it should start. You can disconnect the cable from the lever on the transmission itself and see if you can position it (the transmission mounted lever) to the park position, then try to start the car to check this theory out. Of course, be safe while doing this!
The following 2 users liked this post by MissileDoc:
BigDean (11-23-2020),
Mike Green9 (11-25-2020)
Received 2,887 Likes
Received 4,713 Likes
Just a safety lockout so the car won't start in gear
