Keyless entry FOB: How to access batteries correctly?
OK, here's a lame *** newbie question: My 2009 didn't come with an owner's manual It has a remote entry FOB with a "Valet key" that pulls out of it. How do I safely open the body of the FOB to change out the batteries? Theres an apparent seam that outlines the FOB body, but it doesn't want to pull or split apart easily. Also what is that Valet key for or where is a key slot on or in my '09 that it's designed for???
RetroGuy (12-03-2020)
Here's a link to a free electronic copy of the owner's manual:
https://my.chevrolet.com/how-to-support
Sure makes looking for things in the owner's manual a whole lot easier.
The OM will tell you to use a small screwdriver to open the case, but I will tell you to pull the key out of the fob and use the base of the key to gently pry the case apart.
We've been doing this since the "new" fob came out, and GM realized this was actually the best way and changed it in the OM for the C7 even though nothing physical changed about the case.
Make sure the case is warm (above 80 F if possible ) in order to help prevent cracking.
Thanks for the online link for owner's manual and also for the key fob opening schematic! It appears my valet key is only for locking/unlocking the passenger glove box. Seems odd that's all it's used for on the interior, and there's no lock on the center armrest console.
Thanks for the online link for owner's manual and also for the key fob opening schematic! It appears my valetkey is only for locking/unlocking the passenger glove box. Seems odd that's all it's used for on the interior, and there's no lock on the center armrest console.
Only '05 and '06 have a lock on the center console lid.
Received 2,061 Likes
Received 1,013 Likes
2016 Corvette of Year
2015 C6 of Year Finalist
Also to mention, when you do open the rear hatch if battery is dead, you don't need to climb in to open the front door like some members have done here. On the Drivers side rear wheel well is a pull cord that will open the door.
Also, if you get locked in your car, there is a pull lever on the floor next to the door that will open it.
Warm up the case before you try to open it. Either put it in the sunlight for a while or run a hair dryer on it. This will lessen the chance that your break it while trying to open it. It is a very poor design, and easy to break when you try to open it up.
