2005 C6 With European Tailights
I did the European taillights way back in 2005 when the car was new. At that time the stealer ship tech did it for me as a side job. He back yard engineered the second set of connectors and spliced the second set of connectors into the wiring harness to give the harness two plugs for every light housing. This has worked for years. Now I’m having issues with that wiring harness being glitchy and would like to replace the wiring harness with a new one. However I’d like to stay away from the back yard engineering and splicing into a brand new harness. I found some plug and play harness/adapters for what I think is my situation and just want to confirm? They are from Caspers Electronics and look be exactly what I need for my application. Caspers Part Number is 102067. Can somebody confirm this will fit my C6?
Received 1,596 Likes
Sorry I can't help you, just bookmarking for info and pics.
Will work, but will need to go into BCM programing with tech II and turn on the RPO for the euro harness to work correctly (if not done already).
Patsgarage (01-19-2021)
killain (01-19-2021)
Called Caspers Tech Line to get the question answered. They said that the part number I originally listed 102067 has been superseded to its current number 109042.
http://www.casperselectronics.com/ca...&search=109042
