Aftermarket euro spec led tail lights
Hello, the tail lights i really want for my c6 are the morimoto ones, the problem is that i live in europe and the tail lights have to have amber turn signals...are there aftermarket led tail lights for us poor euro people?
The only ones i found are from sharplightinnovations, but i dont really like the look of those.
thank you
thank you
https://sharplightinnovations.com/sh...ication-for-c6
This would work, but you will need to swap all the rears to LED bulbs and add resistors to eliminate hyperflash. Maybe the company can make a kit with only 2 red LED and this conversion for the inner lights for you.
Just a FYI, but if you are converting a USA car, make sure you go into the BCM programming with tech II to change country use of origin, and select the euro light feature in the option/RPO list to make the wire connector work correctly.
In your case, should already have the BCM set correctly/correct harness in play for your country, and if you are dropping in a USA wired harness, could be a PITA to try to make it work correctly for your country. So having stated such,
https://www.c6performance.net/catalo...-p-493237.html
So having stated such, would better off just using your euro wiring harness, and add in the needed resistors to it to run LED amber turn bulbs.
zenrev (04-19-2021)
Looks like there is an updated version of the RadioN Flyer product available ...
https://www.corvetteforum.com/forums...ht-for-c6.html
