Alternator not charging battery?
My car wouldn’t come on , would click once but all systems ran fine , pointing me to the starter. I had a mobile mechanic come out and replace the starter , with an advanced auto parts starter. The car turned right on after the install, but now I’m getting a Service Charging System message and the alternator is not charging the battery? Tried two new alternators (he said the first new one tested bad) , and still no luck. Any idea what the problem could be?
Race Car Tech
Have you checked the wiring at the starter and alternstor? Did you check the fuse HORN/ ALT/ SENS one member found it blown after his alternator failed.
Hopefully the new alternator is not a Durolast.see attached thread link.
https://www.corvetteforum.com/forums...ease-help.html
Good Luck
Good Luck
icecrxm (04-18-2021)
I take all of my OEM starters and alternators to a local re builder and have them rebuilt. even an 2007 OEM is better grade that the crap that is being produced now. You live in NJ you should have no trouble finding someone to rebuild your original alternator. Either that or purchase a Good aftermarket alternator.
Supporting Vendor
The following 2 users liked this post by subfloor@centurytrans:
2008 Corvette (04-19-2021),
I just went thru this with my friend. Turns out he connected one wire to each solenoid post instead of both on the top one. Car started fine that way but the alternator wouldn't charge the battery. Once he fixed the wiring it started working properly again.
sheesh that might be it , the mechanic is coming back to check it out 😂 let’s see ill let you know. He keeps saying a fuseable link may have burned up but I think this might be it
Good Luck
Good Luck
that was actually the first thing I checked saw a video on YT about that , seems to be fine though
Supporting Vendor
Please update the thread once you get it figured out.
The fuseable link is on the main charging cable off the alternator, on just before the other end of the cable that connects to the starter solenoid terminal.
So low down, alternator cable connects to the starter solenoid, as well as the end of battery positive cable to the same terminal on the solenoid. So could be blown fuse link, or could be that the starter solenoid terminal nut is loose that joins the two cables together instead.
As for the negative battery cable, it bolts to the side of the engine block.
So in this photo, you can see the terminal that the alternator and battery positive cables bolt to to make the connection at the solenoid terminal, as well as the ground bolt on the engine block, and better yet, how the positive terminal on the solenoid has cracked off it, from the heater heat damage to the Bakelite cap on the solenoid.
Note, on the bottom cable of the broken terminal, notice how the heat shrink tubing is longer on that cable. Its due to the fuse link under it just off the terminal connector.
As for the slow blow link, it really use a short section of wire that is 2 gauges smaller than the main cable gauge, so if there is charging problems, it will be the section of cable that melts. So 2 gauge smaller wire for about a inch, fire retard paste on the outside of it so if it melts, will not melt the heat shrink tubing, and then the heat shrink tubing over it and the section of wire/connector that is connected to.
Hey, he at least remembered to install the battery terminal wire on the solenoid terminal, or the battery would not turned the starter.
As for alternator wire dangling, if the fuse link was not blow before, will bank it melted now the first time the end of that cable danced off anything ground to really ground it out. Hell, could have taken out the voltage regulator on the new/rebuilt alternator as well.
But at least you know why most of use wrench on our own cars, instead of farming it out to the incompetent.
I know you’re being helpful but man now I’m scared my car is all f**** up 😭😭😭 and spending more money 💰 😱 you could have held back a little🥲
Supporting Vendor
Despite how tight it is in there, it is still very possible to get that connector attached to the solenoid post.
Supporting Vendor
Hey! Can you help me figure out if my wiring is right? I have a bunch of posts on my account to explain the problem I was having but Now i think it might be this.
