2007 starting problem - LS 2 --- 3LT
Let us know how it works out Jay. Like I mentioned before I have the exact same problem. Even though the symptoms point to the battery, I know it has to be something else. I've installed many new batteries and still barely have enough juice to start the car. Thanks!
Yes please let us know how it works out.
By the way, I have my '08 base coupe with A6 on my lift.
It would be very tight, but there is a chance that the starter could be removed without removing the exhaust. No guarantee. Others could pipe in.
M....
M....
I have tried everything mentioned with no luck. Jumper box, new battery. removed ground from starter and cleaned ( even though it was very clean ) and nothing has worked. Same dead symptoms as before. I think I mentioned before that the last time it even attempted to start very slowly I did smell something electrical like it was hot but the car did not start. Remember this car only has 3,800 miles on it. I ordered it new and it has never been worked on for anything up to this point. I guess that it is possible I just have a defective starter from new that has just gotten worse over the years. I cannot remember the last time that I thought this car started normally. I do not know what I am going to do next. I am very frustrated for sure.
Jay
Jay
Jay
Jay
Jay
Jay
When you try to start it, do either of the battery terminals get hot or even warm?
There's got to be resistance somewhere.
If you smell burning, that's your telling sign.
Jay
#33
Battery cables are not getting hot or warm but the car is also not trying to start. When I push the green start button everything just shuts down. I have no idea what is going on here. I am trying to find someone that can come to my home and work on it.
Jay
Jay
#34
Then you are not getting excessive current draw but you are getting excessive voltage drop which is why nothing is happening. That means there is excess resistance somewhere. Usually this is a loose and/or corroded connection. Sometimes it is a bad wire. It's possible for corrosion of the power supply or ground wires to greatly reduce their current carrying capability. But with your low miles I would be double checking every connection.
#35
Thanks for everyone's help.
Jay
#36
If the car will start using a jump from another car then I suggest you buy a PORTABLE CHARGER. They are light weight, take up no space and can be had anywhere for about $75. My C6 will start on its own about 90 percent of the time but needs a little boost at other times. All parts stores carry them. If you can stand the embarrassment of having all the Mustang and Hellcat people laughing at you while you're jumping your car, then this is the way to go (until you find the real problem).
My wife's Acura has a small drain somewhere, so I have one in her car as well.
