I am replacing a leaking radiator in my 2005 base. Bought a low profile jack and aluminum jacking pucks.
My question is where do you guys put the jack stands? I know it seems like a silly question but I'm asking anyway.
I place them under the front subframe near where the lower A-arms attach. You can use a block of wood to prevent things getting buggered up.
It might be in the manual, but I used a certain section of the aluminum framing under the engine with some cushioning tops for the jackstands. It worked well, but it seems like it would have been more stable to jack there, then use the pucks over the stands.
Still, I’d consider using ramps instead of it’s feasible.
I got it, now lets see if a man who had to ask that question can replace the radiator.
Thank you, I'll let you know how it goes.
Easy, peasy! Just use the radiator petcock to drain, and be especially careful to disconnect the lower hose AT THE RADIATOR!!! It's a pretty easy lift and separate from A/C condenser. Be careful to NOT get any antifreeze on your belts. Thats where the disconnect on the lower hose at the radiator comes in. My belts were in good shape, until a careless T-stat change (yeah, it was me!) got Dex all over them. They squealed like piglets after. Hell, the belts cost more than the new Tstat and lost coolant!!
So in the instructions I downloaded from this forum in figure 8 it says "remove pins that mount the bottom of the radiator shroud to the bumper beam".
Where are they and are they accessed from under the car or inside the engine bay?
Under the car, up inside the bottom air inlet to the condenser/radiator. Though I don't remember having to remove them to change radiators.
