C6 Vert Automatic Roof not completely closing
Hi Folks,
The cover for my C6 Vert automatic roof seems to be struggling to latch the tonneau cover while either opening or closing the roof. It connects to the latch and then it sounds like the motor keeps running and running but won’t actually close completely and turn off. It latches, but won’t close that final 1/2 inch is so. Any help or suggestions would be greatly appreciated!!
Thanks.
Thanks.
I have the same problem....I seem to remember either on this forum or elsewhere that a fellow found a source for the plastic gear and replaced it a lot cheaper than buying a whole new motor system. I have searched but haven't found it yet......right now, I just HELP the tonneau cover down by putting my arm on it and helping it pull itself in.
RoadGlide15 (06-10-2023)
Yes, you are using the wrong names for the different parts....Convertible Top / Tonneau Cover / Waterfall / Tonneau pulldown motor / Convertible Top Actuator motor.
Convertible Top= passenger compartment cover with rear glass window
Tonneau Cover=Hard plastic cover that hides the Convertible Top when in the down position & rear of the top sits on when up
Waterfall= plastic cover between the seats that hides the Tonneau pulldown motor and XM radio receiver
Tonneau motor= motor that pulls the tonneau cover down with either the top up or down position
Convertible Top Actuator motor= motor/hydraulic unit behind passenger seat under side panel
I M Tweety Bird (05-27-2023)
I had the exact same issue in a 2010 grand sport. The gears just kept running and it wouldn’t latch. I replaced the little pulldown motor in the waterfall and hadn’t had a problem since.
It’s that crap plastic that breaks inside. Easy 30 minute swap.
jeffsolomon (05-30-2023)
