ac belt
Old 04-29-2024, 12:52 PM
Stockguy11
5th Gear
Stockguy11's Avatar
Default ac belt
I have a 2012 grand sport with dry sump. It needs a new ac belt.
P/N is 12636224 which GM has discontinued. Does anyone have
a recommendation on what belt to use? Thanks in advance
Old 04-29-2024, 01:28 PM
sobe88
sobe88's Avatar
Double check compatibility, but I believe this is the replacement from Gates.
https://www.oreillyauto.com/detail/c...h/gamv/k040418
Old 04-29-2024, 01:31 PM
jamieo
jamieo's Avatar
I use the Continental belts.They are the replacement belt for the Goodyear Gatorback belt.
Old 04-29-2024, 05:12 PM
Stockguy11
5th Gear
Stockguy11's Avatar
Thanks for the help that’s the one I need
Old 04-29-2024, 09:19 PM
Dano523
Dano523's Avatar
Received 3,051 Likes on 2,194 Posts
Would back it up, and why do you need a new AC belt. Is the A/C tenser pulley going dry and what took the belt out, or is the Ac clutch bearing dry, and what took the belt out? Hence tensioner pulley is easy to pull to re-grease the sealed bearing, as well as the A/C clutch bearing ( and what may be making the noise,with the old belt still fine.
Dbl_D718
Dbl_D718's Avatar
There is an AC Delco equivalent as well, 4K418. I just ordered this one last week, it fits right and doesn't make any noise.
Old 04-29-2024, 09:42 PM
tyler2you
tyler2you's Avatar
Got this one at Advance Auto a few months back. Fit my 2013 dry sump GS.
To ac belt
Quick Reply: ac belt
