C6 power seat won't work
Old 05-02-2024, 04:54 PM
MCruz
8th Gear
MCruz's Avatar
Default C6 power seat won't work
Hi any help I have a 09 base power seat quit working after days of trying to move the seat I finally was able took the seat out and I can't find any wires cut or broken any idea what else I should check I got power from the wires going into the car and then no power after that. Is not the fuse either. the lumbar part works but the back and forth doesn't. Thank you
Old 05-02-2024, 10:03 PM
LarryMow
LarryMow's Avatar
When my seats quit working, it was the plug itself. I guess moving the seat back and forth caused to two halves of the plug to work itself looses just enough to become a nuisance. Plugged it back together, ran a zip tie through the wires pulling the plugs together tightly. Havent had a problem since
MCruz (05-04-2024)
Old 05-04-2024, 05:06 PM
MCruz
8th Gear
MCruz's Avatar
I solved the problem it was a bad wire coming from fuse box , I was able to move the seat by hot wiring the side seat control using the lumbar control with a paper clip .
To C6 power seat won't work
Quick Reply: C6 power seat won't work
