Sometimes these aftermarket radiators need to be massage to fit. For some reason some fit some dont. so dont be surprised if they have issues. Its part of not buying stock parts.
one of buddies had to cut the ears to make it fit. And one had a smalll leak
thanks for the advice.
should an auto mechanic be able to make it fit or should I be concerned?
It depends if you get one that needs some massaging. Is up to the shop you go to, if they want to modify it, if they do you'll probably have to sign off on something so there not responsible. Im just saying that aftermarket stuff is not plug in play, but yes it could be also. Talk to the shop and see what they will say. Could go smooth as silk or not. Not trying to scar u its just what it is with non OEM parts,
Cooling: Additional coolers are added for the engine oil, transmission, and power steering fluid to prevent overheating during high-performance use.
z51 power steering cooler is not apart of the radiator. PS cooler is a separate cooler bolted to the engine cradle in front of the steering rack. I know because I am about to install a csf radiator into my engine bay in my z51.
If you’re speaking of the engine oil coolers, only M6 base cars with Z51 got those from the factory. From 2005 - 2007, the cooler was a heat exchanger mounted in the driver’s side radiator end tank. In 2008, GM moved to an air cooled oil rad mounted in front of the AC condenser on the driver’s side. All the Z51 optioned M6 cars used the heat exchanger in the passenger side radiator end tank to cool the transmission. All cars with an automatic use the same passenger side end tank to cool the transmission. Non Z51 base M6 cars got no extra cooling.
I did my radiator on my 06 last spring. I also did a fabbd alluminum aftermakt one. No problems. If a mechanic cant handle the job he needs to find a new career.
Originally Posted by NELH
z51 cooler is not apart of the transmission. It is a separate cooler bolted to the engine cradle in front of the steering rack. I know because I am about to install a csf radiator into my engine bay in my z51.
Thank you, I know our Z51's have extra coolers, I wasn't sure if they were attached to the radiator or where they are located.
man I had typo city in my comment. I corrected my post but I was referring to the power steering cooler. It’s separate from the radiator and bolted to the front of the engine cradle for z51 cars. At least that is how it is for my 2005 z51.
@FatsWaller is correct about the engine oil cooler and is correct about the m6 & auto transmission cooling options.
