[Z06] LS7 fuel requirements???
Originally Posted by SWCDuke
Fuel system elastomers have been designed for up to 10 percent volume ethanol for the last 20+ years.
No, the sky is not falling!
Does anyone REALLY think that GM (or any other major manufacturer) would build a car that won't operate satisfactorily from both a performance and reliability standpoint in California, which is 30 percent of the US car market?
Well, okay, if you really believe that you better add another layer of aluminum foil under your hat!
Duke
Duke
1 Post
CI 6-7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09
I also personally witnessed Dave Hills announcement in Bowling Green in May of 2005:
93 octane is RECOMMENDED for the C6, but it is REQUIRED for the Z06.
He went on to reiterate REQUIRED for the Z06.
Has he revised that statement? Or has Chevrolet made a WARRANTY statement that the 91 octane available in the western states will be adequate?
I sure hope this is not a case of caveat emptor.
Originally Posted by Kelly100
I would worry more about them adding more ethanol to the gas than 91 octane. I don't know how much the hoses etc can more ethanol. Just a thought. In CA, they will be adding more ethanol
Thanks, Feds! Now our gas is even more expensive, and our engines produce less power.
Michael
Received 1,973 Likes
Originally Posted by glass slipper
Federal law requires all vehicles sold in the USA to be CAPABLE of running on 87 octane.
The Z06 fuel spec is "93 PON recommended, 91 PON minimum", but here's the real deal:
If you don't use 100 PON race gas, your Z06 will be limited to 150 HP!
Duke
Oh!!! So was the USC cite or agency regulation for that one.
Duke
Duke
http://www.epa.gov/otaq/cert/dearmfr/vpcd9701.pdf
An excerpt from the letter...FTP is Federal Test Procedure, SFTP is Supplemental Federal Test Procedure, HWFET is Highway Fuel Economy Test, and finally 91 RON and 96 RON is equivalent to 87 PON and 93 PON or what we refer to as regular and premium.
"Under the provisions of section 27 of 40 CFR Part 86, EPA began to require manufacturers to show, prior to certification, that knock sensor equipped vehicles could operate on 91 RON gasoline without effecting emissions or fuel economy. To do this, manufacturers have to demonstrate that the knock sensor output does not alter spark timing during FTP operation, or that the fuel economy difference between 96 RON testing and 91 RON testing is within 3 percent. Either option requires the manufacturer to run special testing.
EPA has rarely found that knock sensors come into play when tested with 91 RON fuel. There is no likely motivation for a manufacturer to design a calibration that results in spark retard while operating on recommended regular octane gasoline. Therefore, in lieu of test data, EPA will require that manufacturers submit a statement attesting to one or more of the following:
1. The knock sensor does not activate in any way during the FTP (or the SFTP as applicable) and the HWFET, and the calibration is designed to operate on 91 RON gasoline without the need for park adjustment.
2. The city and highway fuel economy test result differences between comparing 91 RON operation and 96 RON operation is ithin 3%, and there are no emissions increases (beyond normal test variability) using 91 RON fuel when tested on the FTP (or SFTP as applicable)."
...Hope this is what you're looking for. Oh yeah, I'm from the Government and I'm here to help.
Thanks for the source info. I wasn't aware of this, but do you know that it's still in effect - kind of casts a cloud on GM's "93 recommended, 91 minimum" requirement UNLESS Z06 won't get through the FTP on 87 PON without timing retard that reduces fuel economy by more that 3 percent.
Duke
Duke
Duke
Duke
...I think (emphasis on "I think") the "93 recommended, 91 minimum" is to get max performance. In other words, you can run 87 octane, you just won't get close to 505 HP but part throttle operation will be acceptable as in very little spark retard. I say this because the FTP and HWFET are done at light to moderate throttle with A/C off and moderate ambient temperature (not 90+ degrees). Given those conditions, I think 87 octane would work with very little spark retard allowing GM to stay within the 3% window. The SFTP is a different story as it uses more aggressive throttle.
...I'll do some more research and see if I can confirm my "bets" and "thoughts".
Michael
#33
Originally Posted by Michael A
I think Chevy would have to say this, because while it will run on 87, they don't want their customers using it, or they will get all kinds of complaints about lack of power and pinging. I'd venture to guess the same kind of cheapskate who would run 87 in a Corvette, would also be the type to sue GM to get some money out of them for how badly their car ran on 87.
Michael
Michael
...Running 87 in a Corvette is not necessarily a bad thing depending on the circumstances and doesn't mean a person is a cheapskate. My daughter runs 87 in her '99 coupe in the winter because the lower ambient temps and less humidity significantly reduces the octane requirement to the point she sees no reduction in HP or MPG. As a college student, she wants to save where she can without sacrificing anything. So from the "cheapskates" point of veiw, they might look at the guy using premium in the winter and think "gee, if that guy was smarter...". It's all about perspective and I certainly respect yours, in fact I've run 93 in my ZR-1 exclusively since brand new...winter or summer.
...There are a lot of variables when it comes to octane requirement and knock, but really, the sky is not falling.
#34
I wouldn't say that "pinging" is not harmful. Sustained detonation such as pulliing a mountain grade can cause damage, but most most detonation on modern cars with knock sensors is usually transient in nature and rarely causes harm, though detonation damage can be cumulative.
The best bet is to reduce throttle or shift to a lower gear if detonation is more than just transient.
Especially with today's high compression ratios and marginal fuel octane, the point of maximum thermal efficiency is the ragged edge of detonation. Modern spark advance maps are more aggressive than would be possible without detonation sensors, so the OEMs set them up for best efficiency, and the control electronics will retard as required if detonation is detected, and inlet air temperature is a BIG factor. Detonation tendency increases as inlet air temperature rises. High coolant temperature is also more prone to detonation. If it's 100 degrees outside and your coolant temp is 220, the control electronics will probably have to retard unless you run higher than commonly availalbe octanes - like 100 PON unleaded race gas, but spark retard is for the most part transparent to drivers.
This is one of the reasons why modern cars get better overall mileage than pre-detonation sensor engines from 10-15 years ago, even though model for model and engine for engine, modern cars are mostly heavier and more powerful than their non-detonation sensor ancestors. Modern engines on average are operating at higher thermal efficiency than older model engines that don't have detonation sensors.
Duke
Duke
#35
Duke
Duke
...Sustained detonation will damage an engine very quickly if not brought under control. However, detonation and ping are two completely different things. Knock implies autoignition and an infinite range of severity can be present. Normal combustion flame speed is about 200 ft/sec. Detonation is more explosive in nature (the rate of the chemical reaction is greater than the rate of expansion giving rise to a pressure pulse from the autoigniting region) with the end gases igniting so quickly the "flame speed" is about 2500 ft/sec. Nonexplosive autoignition (the rate of expansion is greater than the rate of chemical reaction) has a pressure pulse too small to be measured and the "flame speed" is 400-800 ft/sec. With autoignition, two different types of vibration may be present. Detonation will give rise to a very rapid increase in pressure throughout the combustion chamber that will be a direct blow on the engine structure resulting in damage (immediate or cumulative) as we both stated above. The ear will detect a thudding sound from the impact and subsequent free vibrations of the engine parts. Depending on how much of the end gas is left before autoignition occurs nonexplosive autoignition has a small to large pressure difference in the combustion chamber and the resulting gas vibrations can force the walls of the combustion chamber to vibrate at the same frequency as the gas. An audible sound may be evident called knock. Ping is a less severe form of knock occurring when little of the end gas autoignites. This slight autoignition is desirable because it will speed the combustion process at a time when the flame speed is decreasing. Max power is obtained when the spark is adjusted to the point of audible knock. However, severe knock can cause failure, ping as GM advertised, is the sound of fuel economy but is not severe enough to cause damage.
#36
Detonation is "pinging" or "knocking", which are just a verbal descriptions of the sound. Pinging is probably lighter detonation than knocking depending on your point of view.
Detonation damage is due to overheating of the combustion chamber boundaries. The detonation shock waves increase the rate of heat transfer by up to an order of magnitude, which can rapidly overheat aluminium pistons and already hot exhaust valves.
Duke
Duke
#37
For driving around town you don't need anything beyond 87. When you use 91 or 93 on the street you are just buying expensive insurance in case you find a need to go WOT.
