C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] 2006 Z06 Dyno with LG Pro Long Tube Headers
Old 09-28-2005, 10:27 PM
LG Motorsports
Premium Supporting Vendor
LG Motorsports's Avatar
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Default 2006 Z06 Dyno with LG Pro Long Tube Headers
Hi guys,
All this information is with our LG pro Long Tube system WITH cats.
This Z06 is owned by REDLINE OIL president, Tim Kerrigan. He had the car sent directly to us at LG Motorsports. We appreciate his confidence in us.
I will start with some facts. We installed the headers today with only one minor change to our 3" mid pipes. The C6 necks down to 2.5" but the Z06 has 3" mufflers. This only required a small change in our system to eliminate the 2.5" neck down and continue our 3" pipes to attach to the stock 3" mufflers.
ok Results. First I have to clarify some knowledge that I gained in the last 24 hours. Without being able to tune the PCM, Temperature makes a big difference. I am sure that Temperature also lowered our Base line numbers also. So the 443rwhp would have been higher had we cooled the car down more before we did 2 runs back to back.
Our "After" header install numbers were not up to where we thought they should be so we let the car cool down for about 30 minutes then we did 4 pulls in a row with only 2 minutes seperating each pull.
There is no way that I was going to just pick the best After pull and call it good.
Here is all the information for you to digest. the temp on the 3rd or 4th after pull was about equal to the baseline pull, so use this information wisely.
Also note that once we can get into the computer we will be able to go in and "affect" the changes in timing and other parameters that are pulling the power out.
The air fuel went from a 12.2 on the best run to an 11.7 on the worst run (in the 4 run graph)
The first graph is the base line, with a warm engine) against the cool engine pull with a 30 minute cool down.
The second graph is 4 pulls in a row, 2 minutes apart showing heat build up and the effects of the heat on the power.
Base line/After header install with cool engine
4 pulls in a row below
You can see that the computer pulls about 16 rwhp out and 13rwtq
by doing 4 pulls back to back within 6 minutes total from starting the first pull.
Tuning will solve this easily.
Then just for fun, I pulled the air filter and made a quick pull before i left for the day. the car had been sitting for over 30 minutes.
Old 09-28-2005, 10:30 PM
Nourdmrolnmt1
Cruising
Nourdmrolnmt1's Avatar
so i am to assume this is just headers, no cam nothing correct?
Old 09-28-2005, 10:34 PM
07Z06RN
07Z06RN's Avatar
Am I reading this right? Up to 40 freaking hp and 50 ft-lbs with just long tubes? That's awesome !
Doc-ZO6
Support Corvetteforum!
Doc-ZO6's Avatar
Wow
Old 09-28-2005, 10:36 PM
LG Motorsports
correct
Just LG Pro Long Tube headers with cats.
the bottom graph shows 4 runs with headers installed after installation.
We did the 4 back to back so we could know exactly what was happening with heat soak.
since we could not go back and remove the headers we know that the next car will be baselined both hot, and cold to clarify the results.
Lou Gigliotti
__________________
LG Pro LT Headers, MOST HP, MOST TORQUE
http://lgmotorsports.com/gallery/alb...no_compare.jpg
LGM http://www.LGMotorsports.com
Winner Daytona 250
22 WC Wins
"Most powerful Corvette headers on the planet"
Old 09-28-2005, 10:38 PM
Lawdogg
Lawdogg's Avatar
Lou, now your cookin with gas! Some LGM long tubes, get rid of the 2.5" bottle neck and we are starting to make some good power hot or cold. I'm becoming a believer that this engine with a good tune, intake, and headers may be over 500 at the wheels like a 427 should be. Now do a cam and holy schnikees.
Zlicious
Zlicious's Avatar
Holy Sh*t!!!!!
LTC Z06
Get Some!
LTC Z06's Avatar
Wow
roSSco
roSSco's Avatar
Nice work!
Empatho
Empatho's Avatar
thats great and imagine with a tune and intake
Old 09-28-2005, 10:39 PM
Doc-ZO6
Doc-ZO6's Avatar
Originally Posted by LG Motorsports
correct
Lou Gigliotti
Lou, any time frame for the software kits and how does a boy in missouri- get hooked up- we're not even talking cams yet-
LG Motorsports
Thanks and I agree. The tune is critical
We already did remove the 2.5" bottle neck and install a full 3" connection to the stock mufflers
LG
Old 09-28-2005, 10:40 PM
EuG
EuG's Avatar
correct
I assume that's Random tech high-flow cats, not the stock ones, since they'd have to be eliminated by headers, correct?
seayzo6
seayzo6's Avatar
OH YEAH BABY!!!! No cam numbers, just headers. Lou's the man.
C6 Z06 Rocks.
Old 09-28-2005, 10:41 PM
Zlicious
Zlicious's Avatar
correct
Lou Gigliotti
with the stock cats or the aftermarket high flow cats?
JerriVette
JerriVette's Avatar
Received 3,948 Likes on 2,177 Posts
Dam fine performance increase from headers.
483 rwhp? 460rwtq! Wow!
Congrats
Looking forward to seeing what the pcm unlocks for you.
Old 09-28-2005, 10:43 PM
LG Motorsports
Just call me direct. and we can work your car in.
This car is owned by the owner of RED LINE Oil, Tim Kerrigan. He had the car sent directly to us for the first mods.
My own Z06 will be in this week or next and we will try 3 different cams in it. The results of that testing will determine which cam we will install in this red Monster.
LG
To 2006 Z06 Dyno with LG Pro Long Tube Headers
vetterlatethannever
vetterlatethannever's Avatar
WOW!!!!
I am going to play the lottery......
Zlicious
Zlicious's Avatar
.[/B]
I just caught that..AWESOME!!!!!
Old 09-28-2005, 10:44 PM
GeneCamaro
GeneCamaro's Avatar
Wow those are awesome number. I'm curious what the car will do stock with just a tune, no headers.
I'm also curious about that Z06 that dynoed 454RWHP on a mustang dyno from LS1Tech......
Quick Reply: [Z06] 2006 Z06 Dyno with LG Pro Long Tube Headers
