[Z06] LS7 Flow numbers
Premium Supporting Vendor
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
LS7 Flow numbers
Hi Guys,
Here are what we got from a stock LS 7 head for flow numbers.
These heads are already C N C ported from GM. they are a very good head to start with as they come.
Lift Intake Exhaust
.300 246 cfm 174 cfm
.400 302 cfm 200 cfm
.500 343 cfm 211 cfm
.550 358 cfm 216 cfm
.600 360 cfm 220 cfm
.650 379 cfm 224 cfm
We expect to see over 600 Flywheel hp with just a LG Cam, LG Pro Long Tube Headers, filter system and a Tune. I would say about 625-640 flywheel hp very easily with NO head work.
That would be from 530rwhp to 545rwhp.
This car and engine will make "tuners" out of shade tree mechanics.
Lou gigliotti LGM
Lift Intake Exhaust
Lou gigliotti LGM
__________________
LG Pro LT Headers, MOST HP, MOST TORQUE
http://lgmotorsports.com/gallery/alb...no_compare.jpg
LGM http://www.LGMotorsports.com
Winner Daytona 250
22 WC Wins
"Most powerful Corvette headers on the planet"
Winner Daytona 250
22 WC Wins
Originally Posted by LG Motorsports
Hi Guys,
.... (snip)
Lou gigliotti LGM
.... (snip)
Lou gigliotti LGM
Originally Posted by 1955 BelAir
Very interesting!
What is the runner and chamber size ??
Port volume is rumored to be in the 250cc range
LG
Hi Guys,
These heads are already C & C ported from GM. they are a very good head to start with as they come.
Lift Intake Exhaust
Lou gigliotti LGM
Lift Intake Exhaust
Lou gigliotti LGM
however, if you are referring to CNC - that stands for computer numericly controlled.
Lou gigliotti LGM
Low Lift flow numbers ?
Hi Guys,
Lift Intake Exhaust
Lou gigliotti LGM
Lift Intake Exhaust
Lou gigliotti LGM
Do you have the data @ .025 .050 0.1 & 0.2 inches of lift?
It looks like some real porting gains are to be made on the exhaust side....the intake is just fine as is I like to see 70-75% of exhaust to intake flow
If you do please post
THANKS
Originally Posted by tx tuna
not sure what "C & C" porting is........
You are prbably not sure what "Tuning" is either.
LG
Originally Posted by Webfoot
After my car arrives and I get it broken in, I'd like to do a cam/header/intake/tune package (assuming I can find someone here in pineapple land to put it together). But I'm curious how far you can go before the GM warranty is voided. Is the cam a step too far?
Yes,
A cam is a step too far for a warranty. My opinion is that the first step is for the Headers and tune.
I am doing the cam just because I spent the $$ on this car and I want to bring the power up to a level that is just a little bit more thrilling. How often do we get to put a license plate on a car with over 600 hp that drives like this one.
thanks.
LG
THANKS
THANKS
Also keep in mind that this head came from the Le Mans effort where they run 2 very small ristrictors (32.5mm) per their rules. So they developed the intake port to make up for the intake restriction. They knew that they were not going to get the intake charge in, so they didn't need to get it out.
It is a 2.2" intake valve and a 1.6" exhaust. So the 2.2" intake and big port was a crutch for the restrictor plates.
I am sure that Tuna will correct my spelling if it needs any.
Lou G
no offense LG, but i just find it comical that you give a technical disertation on ls7 head flow numbers all while seeminly not knowing what CNC means. next time get your cylinder head vendor to proof read your technical posts for you and i wont have to. again, not being mean here or trying to hurt anyone's feelings.
CNC
Counter-Narcotics Center (CIA); Crime and Narcotics Center
JP 1-02
http://www.dtic.mil/doctrine/jel/dod...m/c/00977.html
I knew there was a reason for your existence
LG
I see you are up to 9 posts again. You must have lost a couple
JP 1-02
LG
LG
LG
this is an interesting response! so what is C & C porting for us less educated people out here?
I made a mistake and wrote C&C instead of CNC which is computer controlled machine work on the cylinder head ports which you probably already know.
thanks
LG
i figured that is what you meant but by your response about "tuning" i thought there may have been something i was missing? I guess not keep the z info coming thanks
Sorry,
thanks
LG
thanks
LG
Originally Posted by Mark Gray
LG, I guess tunaman is perfect, ain't he. I've been following your posts and I really like your work. Thanks!
Go Lou! I too am one of your fans. I love your headers. Sorry you weren't there when I had them installed so I didn't get to meet you. You were busy that day picking up your new Z06!
