[Z06] Just uploaded the stock LS7 flash file-unbelievable!
Supporting Vendor
St. Jude Donor '09
Originally Posted by 90 Corvette ZR-1
wonderful
There is no "Off Board" Programming available yet since the new 32 bit ECM connectors are not available anywhere. I even checked with Vetronix, who are the folks that bring you the Tech 2 and MIS2000 Programming, and they have none.
Within a week or so, I suspect that many tuners will be up and running with the LS7Edit program.
It looks like GM finally caught on the game. For years the Mustangs had a concepts of offering from the factory a modest hp'ed car but with countless options and potentials for mods. I think that is the one of reasons it out sold the LT1/LS1 F-bodies. That game was really continued on with the ricer crowd. $1,000 buys you a lot of cheap powers for you kittle civic, evo's.
Now we have a LS7 that is potentially a 650 hp engine offered at 505. With a little tweak here and there, you got yourself a moster car without having to void your warranty. This Z06 is looking to be the best bargin in the history of sportscars.
Yes, the potential within sounds simply unbelievable. Thanks Jim.
Former Vendor
And yes, the Z06 is a monsters waiting to come out...that baby is very de-tuned; I can't wait to jack around with the PCM parameters
Supporting Vendor
St. Jude Donor '09
We just finished our prototype LS7 RACE filter, so both the LS7Edit Program and our filter got the test today.
One word. What a HUGE difference in performance!!!!
I did a quick a/f ratio tune, timing tables, torque management delete, rev limiter, and a few other tricks.
I think this is the first Z06 to have LS7Edit downloaded through the OBDII.
Lou G. has his up and running now as well. We've been collaborating.
Supporting Vendor
St. Jude Donor '09
Originally Posted by 99blackFRC
gains?
Dyno testing this week if it doesn't snow.
Originally Posted by Jim Hall
Too hard to tell by SOTP and zero traction in 1st, even at a 35 mph roll and new Viper rubber in the rear and front.
You guys keep us STOKED !
I'd guess from what you say ... dyno will be @ 525 RWHP/ 515 RWTQ levels.
Supporting Vendor
St. Jude Donor '09
Originally Posted by bernrex
Best news of the week, month, year !!! Big thanxs to J.H. and Lou.
http://www.corvettels7.com/forum/showthread.php?t=32
Here is some screens of a few torque management tables:
Supporting Vendor
St. Jude Donor '09
Originally Posted by Webfoot
What torque numbers would be produced at the different RPM levels if the computer didn't limit it? Will you change the torque values, or just turn it off completely?
We have already witnessed a rear axle break here on the forum, even with TM onboard, so this area comes with no warranty. Change it at your own risk.
Having said that, it makes no sense to add timing, just to have the launch control pull it back when you drop the hammer.
Dynotech cradles would be in order and M300 half shafts. I would like to see them made in titanium.
#33
I can see why the folks in Detroit/Warren put the TM in there if this is what you see with some early tuning. They have to be able to warranty something.
A 427 ci with the flow that is there in the heads and long tubes from (insert vendor here) that is making 500 rwhp...tweak the tuning...550 shouldn't be crazy.
#34
Supporting Vendor
St. Jude Donor '09
I posted the a/f ratio graph (stock) vs. our straightline 12.8:1 ratio:
#35
I don't know what we added today, but it is a different ride tonight. Our first prototype intake and programming made a BIG difference. How much? Really hard to say in this HP range, but the torque is very noticeable.
#36
http://www.corvetteLS7.com/PE_RPM_Table.JPG
http://www.corvetteLS7.com/peRPMtable2.JPG
Thanks for the tip. Sorry about pics. too big for the forum...go to the links.
If you want to take a screen shot of JUST the program that you are trying to copy, make that window active, and then press Alt+Prnt Scrn. Then save to whatever program that you want.
Not that I dont appreciate your whole screen, BUT it would just be more to the point to see JUST the program's window.
#38
Originally Posted by Deep Blue
Forgive me for being ignorant, but what is GM's goal with torque management?
#39
