[Z06] Ls7 Rx7
4th Gear
I have owned rotaries before. 4 to be exact. I will never own another. TTRotary, you need to do some research before you TRY to give people info or advice.
Originally Posted by 2MCHPWR
I'm trying to enlighten you but if you still are resistant to listen to these facts, you are a typical rotard
Having seen your site (couldn't get there earlier - came up as "****" on POE server), I am convinced the swap works well. I am still mystified by the weight distribution since the engine is obviously further forward in the chassis than the 13B would have been, and the T56 is presumably heavier than the Mazda Ribcase trans. Perhaps the LS1 is lighter than the fully-dressed 13B-REW. I know my friend's turbos alone were 65lbs w/ the manifold. In any case, kudos to the builder for a nice job. However, it is also obvious from your pictures that this was a major project - much more than a simple swap "in your garage".
Apart from this...why bother. Just get a Corvette.
Norotor or whatever your name is: if you are going to use bandwidth, try to come up with a useful post - especially if it's your first one.
I would have kept the '93 R1 I had because it was a nice looking fun to drive car had the motor been the only issue. When I got rid of mine it had 104k miles. The interior was falling apart, the windows wouldn't hardly go up and down door trip panels were broke, tachometer quit working. There were suspension clunks. The alarms system would go off if I opened the trunk first instead of the door. Alternator crapped out. Transmission grinded into 5th gear.
In the end I was afraid what would brake next and quit driving it and was happy to sell it. The car was a great idea but not well executed. One of my friends had a '94 R2 and when when he got rid of it at 45k miles the motor was already losing compression and needing a rebuild.
2MCHPWR and TTROTARY.....I thought I stumbled into the tech forum for a second.
I applaud both of you for having a constructive conversation that could have easily ended up ugly and locked. Hurray for civility.
I try to learn something new each day, and you both helped!
Viper 3470 lbs/510hp = 6.80 lbs per HP.
C6 z06 3147 lbs/ 505hp = 6.23 lbs per HP.
My RX7 (400 wheel hp = approx 460 crank hp)
2730 lbs / 460 hp = 5.93 lbs per HP
sounds like a bargain to me
Can't argue with the numbers though.
1 Post
St. Jude Donor '12
I strongly considered doing an LSX swap into my FD (see sig) before I sold it. I don't regret my purchase though. The Z06 is considerably more well-mannered although more common. Someday, I'll buy a very clean FD and drop and LSX in there for fun.
Doing an LS7 would be a waste, IMO. There are other ways to make great power much cheaper (LS2 402). I used to dream of an LS7 FD, but the only reason for doing it would be for the LS7 name.
Factory has clearly indicated LS7 CANNOT be re-sleeved, because there is not enough material to re-mill the bore. Also, if the liner splits, it will also split the AL surface behind it.
As for Lingenfelter, it is guaranteed because the $46K price tag includes 2 spare motors
Seriously, that's damned impressive, but I doubt there is much life there unless compression is reduced. Quick math says that is 8-10psi, which is at 11.0:1 CR, even with highly efficient intercooling.
Also, I'd like to see you build three 800 HP LS7 twin turbocharged engines for $46K. Three crate LS7s will set you back $42K alone.
This is Lingenfelter we're talking about, of course the compression is reduced...with new FORGED pistons, the factory cast pistons would not tolerate this boost/HP level. There will be plenty of life in this engine, you can take that to the bank.
Originally Posted by cdk4219
Jim LaBreck never got his finished
One of these days I hope to be able to make unsubstantiated claims about how much power it puts down and then back down from a $1,500 challenge race my big mouth got me into. Sound like a plan?
more talk than do for him
1 Post
St. Jude Donor '12
Son, I got a 'lil challenge for you: look under your name and review your post history. Your challenge is to show us ONE single instance where you provided anything of any use whatsoever to this forum. Anything at all...technical info... insights... etc. Yep, didn't think so. The magnitude of your uselessness is staggering.
If you want to learn something about engines, get off your lazy posterior, call an engine builder and learn the facts about what happens when sleeves crack on a block milled this thin. The rest of us are not here to educate you.
---Edited for civility
#33
Even V. 1.0 was polite...
Jim, I recall you obtained and weighed several candidate engines, including and LS1, a 20B, and an LT1, against the 13B. Could you share that info with us, if you still have it? Thanks.
Originally Posted by jlabreck
Nope, never got it finished, but I'm still working on it when I have time.
#34
haha, i/we get that a lot. when was the last time you saw a 2730 lb vette with full interior driving around on the street? not too often i'm sure. how many used vettes have you seen sell for low $20k's that have weight to HP ratio of 5.9? need i go on?
A C6 z06 with LG/Kook Headers, CAI, medium sized Cams + tuning 3147 lbs/ 560rwhp or roughly 650bhp = 4.84 lbs per HP.
Your RX7 (400 wheel hp = approx 460 crank hp)
Still, I agree that 5.93 number is greaet for the investment you puttin.
#35
MONARTOR
Personal attacks/hostility toward others
The Forum should be a place where we treat one another with civility so that it remains a fun and friendly place to hang around with other Corvette enthusiasts.
Personal attacks cannot be tolerated. Attack ideas, not fellow Forum members.
#36
#37
The bodies on these cars were super tight and solid. Suspension clunks are known issue, but are readily fixed with new bushings. Grinding / stiff shifting trans also a known issue, which could be improved with redline synth or royal purple. All cars have issues, and my new C6 is no exception.
#38
Originally Posted by TetraU
I'd like to offer a minor adjustment to the #'s:
Still, I agree that 5.93 number is great for the investment you puttin.
There are turbos out now that make 450 rwhp on pump gas @ 15 psi which spool fast on the 13b.
You have a 2650 lbs car with 450 rwhp (530 flywheel)
2650 lbs/ 450 rwhp or 530 crank hp = 5.0 hp per pound. Now toss in some race fuel and crank up the boost. 600 plus rwhp.
#39
A fully dressed (full accessories, cast iron exhaust manifolds) LS1 is reportedly in the ~460 lb. range, and this is supported by the weights of converted 3rd gen. RX-7s after the LS1 swap.
The LT1's iron block adds another 75 lbs. or so, although a "bare" (no accessories, no exhaust manifolds) LT1 crate engine I bought was listed as 475 lbs. (Oak Harbor Freight weight) with the crate, ECU, two harnesses, and a few other duplicate parts (extra water pump, extra balancer, etc.). With accessories and exhaust manifolds, I've seen ~505 lbs. quoted.
My 20B was listed as 525 lbs. in its crate (again, Oak Harbor Freight), with turbos and full accessories.
BTW, for those currently comparing power to weight ratios... you do realize that a peak horsepower number tells you absolutely nothing about how the car accelerates, right? The acceleration curve (g-force) mirrors the shape of the torque curve and power to weight ratios totally ignore gearing, which is the other major factor in calculating thrust at the contact patch, which determines the acceleration curve (assuming adequate traction).
Power to weight ratios are almost as meaningless as power to displacement ratios.
#40
1 Post
St. Jude Donor '12
Can't you do both?
