[Z06] Will this Eliminate Glove Box and Center Console Heat...
Originally Posted by forhamilton
Foosh
Agreed if I lived in a colder climate. I live in Corpus Chrisi, Texas. Always hot and humid. I installed the 160 degree thermostat to lower temperatures at the track.
I live in a warm climate too. At cruise, I see about 194, and it gets there quickly because the stat stays closed until it sees that temp. In town, with lots of stoplights, I see up to 224, even with the stock stat.
At most you might get an extra few minutes of cooler temps at idle after startup, but if you're high-revving below 190, you aren't doing your engine any favors.
Foosh
Dr. Chill and Foosh
Why do all the tuners recommend the 160 stat? Is it wasted money?
Think about it. It's just a valve that stays closed until a rated temp (160, 180, 190, etc.), after which it stays open until the car is shut down and cools below the rated temp. If GM decided the engine was better off getting to 190 as quickly as possible for better lubrication purposes, I'd rather trust that. They're the ones paying the warranty bills.
Once the t-stat is open, it's open, and it makes no difference in the engine's operating temp. The engine's operating temp is a function of HP, compression, amount of fuel ignited, cam design, the radiator's capacity, amount of air flowing over the radiator, etc. The t-stat has nothing to do with any of that.
Dr. Chill and Foosh
I doubt that a lower temp thermostat would have any affect at all on the exhaust gas temp and would be of little use in dealing with the OP's issue.
Again, I'm no expert though.
EBS
Originally Posted by Foosh
I didn't know they did, but I have no clue why they'd recommend it. It makes no sense, and I believe it's totally wasted money.
This will keep cool.
Cheack this out!
http://www.thermotec.com/products/full/16570/16570.html
Also call Turbo City in Orange, CA. They have a sister company that makes the tiles for the Space Shuttle. But they also make custom heat shield blankets? What if you just wrap the exhaust with a Thermo Shield blanket? If you keep in the exhaust this will do 2 things: 1) Keep all heat in exhaust not glove box/tunnel. 2) Add HP by helping the exhaust to be pulled out more effeciently. (Who knows the math on this?)
Turbo-City
Address: 1137 W Katella Ave, Orange, CA 92867
Phone: (714) 639-4933
Turbo-City
Originally Posted by Slim Shady
Cheack this out!
Turbo-City
Turbo-City
When I put the LGLT's on my C5Z I also installed the 1/4 " aluminum heat treated Elite Tunnel plate at the same time, no heat issues in the cab what so ever, and it made the chassis stiffer. Killed two birds with one stone. I will do the same thing to my C6Z when it gets here.
Originally Posted by AutoCutter
I installed the Thermo Tec Tunnel heat shield too, and it has been this best money spent so far, Summit has it for $230 http://store.summitracing.com/partde...5&autoview=sku Way better than KoolMaster since it covers all of the tunnel, not just the top. The cabin is nice and cool as is the inside of the center console.
It seems that they only have it for C5 not C6 Z06's.
#34
Originally Posted by Z-Jay
That's great BTW what are the Flaps on the outside of the Eye Loops straight line?
#35
I spoke with Thermo-Tec and they say that their C5 Tunnel Mat does not fit the C6 and that they do not recommend cutting it.
Possibly their exhaust pipe heat shield might be a good alternative. It comes in a three foot length and looks like it could effectively shield the tunnel area from exhaust heat.
http://www.thermotec.com/products/full/11600/11600.html
#37
It does, indeed, fit the C6 with no issues that I could detect. All the holes line up and took it about 30 minutes to install as I didn't have any problem working around the exhaust pipes while they were place. I tried the 3 foot exhaust tube shields and they do work to a very lesser degree, but in no way does it compare to the full shield.
#38
AutoCutter you were able to install this without removing the Exhaust?
Please let us know if you ran into any problems. Thank you
#39
It's great to hear that it does fit the C6Z. Evidently Thermo-Tec simply hasn't bothered to check out the fit. I suspect they will be getting an unexpected surge in tunnel heat shield business.
#40
Of some note many of those bolts were not tighten properly-fact is some were damn loose-anyway I tighten them all to about 25-28lbs and that seemed to stiffen up the frame. As an alternative to the blanket and very boring bolt work, I see the Hi Temp Dynomax type products working really great in this area. My next project is to use those old 3 foot exhaust tube shields and use them were the pipes go over the T'axle and almost touch the trunk area. GM put a cookie sheet shield up there, but the trunk area has enough heat to melt a couple of candy bars we had in our luggage(yuck, what a mess that made ) However, the bottom line is whether you use the plate, blanket, or tubes, don't let the heat get into the car; all inside(cabin) insulation does is to keep the heat that found its' way in trapped in the car!
