[Z06] What Fuel To Use When Filling Up The Z06
I am just curious to see what gas everyone is using for their Z06. I've been using BP, but just recently been filling up at Sunoco.
i own a Velero truck stop (built new in 2002). i'v been in the business for 19 years and used to have a Fina truck stop. Velero is very good gas. the best IMO is Fina but they are going out of business is 08 and their stores have been mostly re-branded.
if you live on the boundry of a big city, choose non-RFG over RFG gas
btw, Quick Trip uses unbranded gas which sells 1-2 cents cheaper at the rack than the brand name gas.
non branded are cheaper to make because they omit some of the additives used in brand name gas.
the brand name gases like fina,exxon,mobil, ect are moslty on the same level so you're basically shopping for heighest octane or best facilities.
for the best fuel, choose on the following 3 criteria. the most important factor is the station itself. older stations can introduce contaminents into your tank because they have old in ground tanks, lines, pumps.
next choose on branded over non branded to get the additives and then on octane rating.
Exxon and maybe Citgo are the only ones of your choices that live in SoCal. I'm really not that fussy - BP Arco tends to be the cheapest of the branded gases out here, so I'll use that if convenient, and also Exxon and Shell, sometimes but rarely 76.
I use Mobil because of the speedpass convenience.
Sunco is not in So Cal area, atleast in San Dieog. Any branded station like Exxon, Cheveron, Shell are the way to go. You really should mix 50/50 unleaded 100 oct. to get the most out of the aluminum Ls7, anything less and you really are not getting all you paid for with respect to performance. The 91 pump is weak, and you can hear it ping, watch the tack surge and feel the car gitter here and there.
Found the same to be true in two different Z06 2006 and 2007....same
motor.
motor.
I hope it's not hurting anything, but I am only using Sunoco GT 100 fuel in my 06 Z06. The local station has a dedicated pump for it. I just don't want to put anything with ethanol in my car. It's not my daily driver and only in use on weekends. Now that Ultra 93 ( NJ ) is around $3.50 , I'm not even feeling the $6.50 a gallon price of the GT 100. The only complaint is the race gas smell when I get in the car after not driving it for a few days.
Mickey
06 LMB Z06
Mickey
06 LMB Z06
What is the highest rated octane you are able to get in LA? In the San Diego area it is only 91 octane. I only buy Exxon/Chevron for the Z06.
Thanks,
BadboyZ06
Chevron, Shell, Exxon in that order if available. I also like newer stations(newer tanks). If not, then I look for non-blended gas. In my area blended gas is not required, but some do carry it. My least favorites are ARCO and 76 (although I used 76 recently at an HPDE day because I was so low on fuel and station was across the street from the track-I didn't notice any performace difference).
Here is everyone's lesson reading for Top Tier gasoline.
http://www.toptiergas.com/index.html
http://www.toptiergas.com/retailers.html
Originally Posted by BlaznZ06
QuikTrip has to meet the same standards as branded stations with their grade of gasoline to be recognized as top tier.
if i switched to the QT gas, i can save that 1-2 cents but dont want to go non branded
Originally Posted by Road Hog
87 Grade And The Cheapest Amount Of Money Per Gallon.
I use Sunoco when I can.The local station use to Carry 94.Now they only Carry 93.I used 101 at the track once when I ran out of gas.I must say there was a noticeable difference in throttle response.At $6.50 a gallon I was glad to see an improvement.
