[Z06] 2008 Z06 X-pipe????
2008 Z06 X-pipe????
Does anyone know if the new 2008 Z06 has an X-pipe installed by the factory?
I am not sure if they equip the Z06 with an X-pipe for 2008, or any year for that matter.
Pictures would be nice on whatever is stock installed if you have them.
Thanks in advance, Joe
There is no real reason to add an x-pipe on the stock exhaust..it wont add any more power. I can see getting one on an aftermarket exhaust to reduce "popping" on decel...but I like that sound. If you ever plan to add headers it would be best to wait and get one with the headers as it will require a different size x-pipe.
St. Jude Donor '08-'09-'10
Corsa's X-pipe - and I assume most others - should fit right in.
I 1st run w Corsa axle back and stock H-pipe(2008 Z) and then swapped to Corsa's X-pipe. Easy swap.
I have to say that I don't notice any difference in sound on deceleration between the X- and H-pipe. I swapped as I believe an X-pipe flows better than an H-pipe.
/Nik
/Nik
Thank you all for your insight. Not having the car yet and reading all kinds of GOOD stuff here has encouraged me to research more on simple/subtle things to do to the Z when it arrives next month.
I do not want to mod it too much in the beginning because I want to see if the power and handling are more than enough for me not having driven one yet.
I drove a couple of C6's and thought the power/handling was fairly good, but after joining this forum and seeing and reading the mods folks do, thought that I would explore some.
If you have more ideas, please share.
Again thanks for your input, Joe
