Z06 11.13 127.20--New Best for a C6Z06 Bone Stock on Stock Tires - CorvetteForum - Chevrolet Corvette Forum Discussion
Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C6 Corvette, 2005 - 2013 > C6 Corvette ZR1 & Z06
Reload this Page >
[Z06] 11.13 127.20--New Best for a C6Z06 Bone Stock on Stock Tires
C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Advertisement
Old 11-25-2007, 08:59 PM
Ranger
CF Senior Member
Support Corvetteforum!
Ranger's Avatar
Default 11.13 127.20--New Best for a C6Z06 Bone Stock on Stock Tires
Had the good fortune today to hook up with several members of the Corvette faithful for closing day at Maryland International Raceway in Budds Creek, Maryland. Together with dgdoc, hookedup, proney, chempowr, and Lionel, I made some passes in cool fall air. We enjoyed the camaraderie and exchanged insights from watching each other's passes. And I particularly appreciated the video and engineering skills of my car crew, Beth and Justin.
Last year I predicted that the lower limit of a bone stock C6Z06 on stock tires would probably be 11.15. Today on literally my final pass of the 2007 season, I combined in a single run strong 60’ (1.76) and 330’ (4.80) together with the best 330’-1320’ incremental (6.33) that the good fall air (zero-foot DA, measured track-side using a hand-held weather station) would support. The net was 11.13 127.20. It even included a good reaction-time of .050, something never possible when I had been running a suite of data logging, video, and audio equipment that needed activation after staging.
Here are the details of the record pass:
60'.............1.761
330'............4.805
660'............7.271
660’ mph..…100.31
1000'.......…..9.367
1320'........11.138
1320’ mph..127.20
Traction System Off; one push of the console button. That setting in a C6 allows wheel spin but retains the aggressive form of Active Handling to help the driver regain control if the car gets loose.
Rear psi set to 26 psi; fronts to 40 psi. Both readjusted in the staging lanes right before the pass.
As always, I drove around the water box and backed up to just dampen the rear tires. Pulled forward to the leading edge of the damp area; then heated the rears just to first smoke, at which time I went to clutch-in.
After taking particular care to align the car in the racing groove, I made a shallow stage, just barely tripping (turning on) the second pair of bulbs.
Launch rpm was 3650 with a very fast clutch release and throttle squeeze. Got a touch of wheel spin, followed by some bog. Then nothing but max acceleration.
All shifts were made at an indicated 7000 and included 100% lift of the throttle during clutch-in.
After staying on the throttle to an indicated 130 and crossing the 1320' stripe, I reviewed my mental driver's check list and concluded it had been a very clean pass. That’s an elusive goal in the C6Z.
There may be a few more hundredths it the car; but I may leave them for another driver to find.
Two videos of this 11.13 pass were made, one by Beth using my HD camcorder, and one by Chempowr's lady. I will edit in links over the next few days once the videos are prepared for the web.
Great meeting chempowr and his lady and proney’s lady.
Between now and next spring, I will be missing my racing buddies and the sights, sounds and smells of the track.
Best to all,
Ranger
Ranger is offline
Old 11-25-2007, 09:05 PM
07WhiteDevilZ
CF Senior Member
Hey you could always come up to atco there open almost all year long. They only close in december I will be there friday for a track rental. Nice runs with the car maybe ill see it run one day in person.
George
07WhiteDevilZ is offline
Old 11-25-2007, 09:07 PM
jimmy j
CF Senior Member
You are the MAN!!!!!
jimmy j is offline
Old 11-25-2007, 09:08 PM
Geneus
CF Senior Member
Ranger,
Congrats...the bar just got set higher...again.
Geneus is offline
Old 11-25-2007, 09:10 PM
GaryZ06
CF Senior Member
GaryZ06 is offline
Old 11-25-2007, 09:21 PM
0MR Z
Former Vendor
Nice pass. Lets get some video up!!!!
MR Z is offline
'06 Quicksilver Z06
CF Senior Member
'06 Quicksilver Z06's Avatar
Fantastic.
Originally Posted by Ranger View Post
Had the good fortune today to hook up with several members of the Corvette faithful for closing day at Maryland International Raceway in Budds Creek, Maryland. .....I combined in a single run strong 60’ (1.76) and 330’ (4.80) together with the best 330’-1320’ incremental (6.33) that the good fall air zero-foot DA, measured track-side using a hand-held weather station would support. The net was 11.13 127.20. It even included a good reaction-time of .050, something never possible when I had been running a suite of data logging, video, and audio equipment that needed activation after staging.
I am so glad that you included this in your post.
Too often we get "DA measurements" using data taken from off accuweather.com, or http://www.wunderground.com/ using weather stations which may have been located miles from the actual physical location of the track, and taken at "time intervals."
Its good to see someone post up that they obtained an accurate density altitude reading using a weather station track side.
'06 Quicksilver Z06 is offline
Old 11-25-2007, 09:51 PM
Short-Throw
CF Senior Member
Short-Throw's Avatar
Ranger how satisfying for it to be your last pass of the season!
Ranger, if so, where does that place your goals next season? Consistency?
Way to represent!
Mike
Short-Throw is offline
Old 11-25-2007, 10:10 PM
hookedup
CF Senior Member
hookedup's Avatar
John, congrats on a great run
I was watching from the fence and saw the hint of wheelspin and a slight hesitation when it hooked so I didn't expect that 11.13 to show up! There's more left in that car, see ya' next year when you hit a new best!
Dave
hookedup is offline
Old 11-25-2007, 10:37 PM
Steve Theodore
CF Senior Member
Steve Theodore's Avatar
Congratulations are in order yet again!
Steve Theodore is offline
Old 11-25-2007, 10:58 PM
Turbooo2u
CF Senior Member
Another great pass from one of the most helpful and selfless members of this forum.
Turbooo2u is offline
Old 11-25-2007, 11:03 PM
WeaponsGradeTorque
CF Senior Member
WeaponsGradeTorque is offline
Old 11-25-2007, 11:09 PM
1985 Corvette
CF Senior Member
1985 Corvette's Avatar
Great work. Doing what you love and turning it into a science at the same time. Gotta love that. Too bad you can't do some serious seat time in a ZR-1 or an LT4 and see what times you can turn. Maybe you already have and I just haven't seen it yet.
1985 Corvette is offline
Old 11-25-2007, 11:11 PM
1-2-b-67L89
CF Senior Member
1-2-b-67L89's Avatar
What was the track temp. Ranger as I thought that might not be optimum. Congratulations
Chick
1-2-b-67L89 is offline
Old 11-25-2007, 11:13 PM
vdshenoy
CF Senior Member
vdshenoy's Avatar
St. Jude Donor '08
Good job!
vdshenoy is offline
Old 11-25-2007, 11:28 PM
linutux
CF Senior Member
CONGRATULATIONS!!!! GREAT PASS!!!!
What a great way to end a season!
I believe 0.050 is the best RT on the fast list; is it not? Just can't leave anything for us mere mortals can you?
What have been your best 60' and 330' times bone stock on stock tires?
I assume these are the most difficult sectors to master in the C6Z.
linutux is offline
Old 11-25-2007, 11:39 PM
GARY2004Z06
CF Senior Member
GARY2004Z06's Avatar
Ranger,
Awesome as usual. Congrats on achieving your goal.
Do you think an 11.0x or possibly do I dare say a 10.99x is within the realm of the car in fantastic weather conditions with phenominal track prep???????? (ie. Atco 11/24)
As eluded to earlier, what's next on your agenda?
Gary
GARY2004Z06 is offline
Old 11-26-2007, 12:05 AM
Dr.Ron
CF Senior Member
Dr.Ron's Avatar
Location: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Fabulous run John. Seems like you did everything right on one individual pass- not an easy feat!
Nice 60' time on the stock F1's as well!!! Once again, you ARE the man!
Ron
Dr.Ron is offline
Old 11-26-2007, 01:25 AM
0MR Z
Former Vendor
Ranger, I was wondering what type of weather station you use to tell the DA when you are at the track. Also I was wondering what your times and mph's were on the other runs you had today. Congrats again on the new best.
MR Z is offline
Old 11-26-2007, 03:07 AM
4DCYKEY
CF Senior Member
4DCYKEY's Avatar
Great run.
4DCYKEY is offline
Quick Reply: [Z06] 11.13 127.20--New Best for a C6Z06 Bone Stock on Stock Tires
Sponsored Ads
Vendor Directory
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
