[Z06] Custom Billit Throttle Bodies!!!!
http://www.revxtreme.com/specials.htm
90mm $465.95
95mm $469.95
100mm $499.95
We have the wiring harness adaptors for the C6 applications in stock as well.
These are awesome, especially for the big cube builds.
Prices are for fly-by-wire models, call for F-body cable models.
90mm $465.95
95mm $469.95
100mm $499.95
I do believe this fantastic 100mm unit help contribute to the awesome results of our latest engine tweaking efforts.
It is a very well made, quality unit, and on my application is even smoother than the ported LS2 TB it replaced.
I do not however believe anyone should expect to "pickup Xhp" just slapping this TB on their setup... be sure to discuss with your engine builder/tuner/wise friend about your entire package.
I would hate to see people bad mouth these great TB's because they were applied to incorrect setups
Appropriatly integrated into the correct combination its one of the best mods dollar for daller.
Premium Supporting Vendor
We're going to be getting a 95mm unit & installing it on a ls7 intake very shortly. RC45 did you use a 100 on a ls7 intake? How'd you get that intake opened up that large? I didn't think it would open up that much.
It's all the combo.
Always a hard concept to get across that unless the part being installed in the intake (or exhaust) is the largest restriction you won't see a power increase. A 1500 cfm TB with a 1000cfm MAF on a motor that wants 1300cfm means until the MAF is swapped you see no gain. Sad part is like you said, people will bad mouth the part and it's not the parts fault, it's the persons lack of understanding that it's all about the combo. Of course if your engine only needs 900cfm then you can bolt all the stuff you want on and it wont make a difference. Except maybe mess with your drivability. Looks like a very nice part. Wish I needed the airflow. Heh.
You will need the wire harness adaptor for this.
