[ZR1] Car & Driver now states 3.5 0-60 times
#41
The reason other than bling is to fit larger brake disks. From a 90 series tire down to maybe 40-50 series tire it may improve steady state lateral acceleration on a flat surface. Below that I expect that the lack of sidewall height starts to hurt that due to insufficient flew to keep the trad planted. Another reason is to get a wider tire with the same height.
It is not about increasing the over alltire height to get a longer patch.
Lately t been mostly bling. It is a case of too much of a good thing. past a certain point it only hurts handling due to greater unsprung weight, worse braking and acceleration due to increase rotational mass.
Look at Top Fuel and the top cars in the modified classes in autocross. You won't find any 22" or rubber band tires.
#42
Received 4,373 Likes
If that was the only case, why do they have 20" wheels on the back where the brake discs are smaller, and 19" wheels on the front where the discs are larger? Do you seriously think that's just for "bling"? No - it's because the 20" wheels provide a larger overall contact patch for increased traction and power transfer to the ground on the drive wheels. I do agree with you that a strong reason for the larger wheels is to fit bigger brakes, particularly on the front, but that rationale doesn't cut it for the back ones.
You can get that tire height without going to 20" wheels. It makes for a heavier tire wheel combination.
When they out brought the Lotus Elise Series 2(one of the finest handling cars in the world) they brought out with 17/16 instead of the 16/15 wheel combination it had in earlier model. They questioned the engineers why, and they replied it was a "marketing decision".
Actually, that they are larger on the back is strong evidence it is for bling. It adds to the look of rake, that implies speed.
Shorter stiffer sidewalls reduce contact patch.
If it improved traction, both Top Fuel and F1 cars woud have 24" wheels.
#43
The new tire compounds are amazing, but they can't overcome the laws of physics. The contact patch has to transform 600 ft lbs of torque into violent forward motion for a 3300 lb car!!
Another approach to rapid 0-60 acceleration: take a 1300 lb Ariel Atom, add a 245hp supercharged Ecotec 4 cylinder engine mounted directly over the rear wheels...and get 0-60 in 2.8 seconds! Of course, with the poor aero you hit a virtual brick wall by 80-100mph.
For 0-60 fanboys, go light. Everyone else, welll...you know...
#44
If you want sub 3.5sec to 60mph you need AWD and a ton of power.
#45
#46
Looks like were gonna hafta agree to disagree......
Look at the overall wheel/tire height on a top fuel car - it's huge! They do that with a relatively small wheel and big tire to get a big flexible sidewall. They also run very low tire pressures, so as to allow the sidewall to flex and deform under hard acceleration. The tires are actually screwed to the wheels so as to prevent slippage or bead failure! All of that is designed to facilitate linear grip along the direction of travel by maximizing the contact patch area and duration. They could care less about lateral response.
F1 cars - or auto x as you referenced earlier - put much more emphasis on lateral response (cornering) by having stiffer/shorter sidewalls. Again, for a given maximum overall wheel/tire diameter the best combination of lateral response and maximum contact patch is achieved by having the largest possible wheel and shortest sidewall height. Remember, though, that in F1 the tire sizes, compounds, and tread patten are precisely regulated so as to attempt to equalize everything except the chassis/engine/driver. That's why you don't see bigger sizes in F1, not because it wouldn't be better!
Do you remember the Tyrell F1 car of the 70's which actually had six wheels/four front of smaller diameter in order to both maximize contact patch and reduce aerodynamic drag? It worked - until they regulated it out of existance!
Just because you don't see them using it doesn't mean they haven't thought about it or wouldn't like to!
#47
I thought that one of the benefits of going to a bigger diameter was that it increases the length of the contact patch, thus increasing the overall contact area for a given tire size. That, combined with the increase in width, should improve the grip and traction. Combine that with the launch control on the mag ride suspension and I'll bet the ZR-1 does get more power to the ground than a ZO-6.
Why else have wheel diameters been steadily increasing on performance cars over the past 20 years? Remember when 16 inchers were the hot ticket? The increase in diameter ain't just for the "bling" factor!
My feeling about manufactures going bigger with rim sizes probably has to do with bling factor (no performance benefit but it's a benefit non the less) and because bigger rims= better gas mileage. Imagine if the C6 was running 16's, the gas mileage would be poor as hell.
#49
But given the same rubber compound and tire diameter, increasing the width of the tire does not increase the contact patch size, it only changes the shape. When going wider, you actually lose forward traction, because the contact patch gets skinnier front-to-back. Again, it's better for cornering.
Serious.
#50
Tire diameter vs sidewall width affects traction as mentioned above. With minimal sidewall flex you don't get much more traction as the rear suspension is compressed during launch. Better for cornering though.
Serious.
Serious.
#51
Kind of like rubbing your hand on surface in long direction vs sideways. As long as pressure applied is the same ... grip should be same.
I say its tire compound & operating temperatures, tread pattern, sidewall flex, and road surface adhesion variables ... that make for launch traction differences.
#52
Maybe not... but a mechanical engineer from GA Tech told me this (he owns a BMW performance shop now)
shape matters.
Actually one of the primary reasons race cars use wide tires is for heat dissipation. Thinner tires handling the same load would melt.
Contact patch size has not changed .. thus forward traction should remain the same.
#53
First, if the weight of the vehicle and the tire pressure remains the same, the tire size will not matter on contact patch area. The wider the tire the shorter the contact patch. The narrower the tire, the longer the patch. Since this is true, it would follow that tire size doesn't matter. But it does, and the only thing different is patch shape. It has been found that a tire grips best when the patch is longer in the direction of the desired traction.
So the concept of a drag tire becomes complex. You can only make a tire patch so long by lowering tire pressure and having flexible sidewalls. At some point, you have to make it wider too.
You want a roadrace tire to have very stiff sidewalls to prevent deformation of the tread to pavement and rollover. The wider the tire, the more LATERAL grip. In this case, lowering the pressure to elongate the patch is not desirable. Although to some degree it will help if it's not so low that it allows the tread to distort from lateral G forces.
#54
....I'm pretty sure that the tires on this car were not optimized for either 0-60 or 1/4 mile stats. I'm pretty sure they are a low profile sidewall design for cornering prowess, and good top end safety and stability. Sorry, but you 0-60 and 1/4 mile fans will just have to bolt on some temporary wheels/tires to optimize those specs.
#55
That is PRECISELY why the 20" wheel with the attendant 25 series sidewall is all but useless in dragstrip style starts.
#56
Of course, that is assuming a 4000+ rpm launch. Even off idle, you're looking at at least 1500 or 2000 ft lbs...
#57
I agree....................
19s.......
#58
And clearly a 20" wheel is heavier and harder to accelerate than an equivalent 19"....but the wedge shaped C5 and C6 requires a larger rear diameter wheel. The 20" wheel is a compromise, dictated by form over function.
#59
Never mind................
But they didn't go significantly taller on the tire. 25% of 335 mm is not significantly taller than 25% of 325mm (Z06). To have any semblance of improved 0-60 times, they would have used a tire like the Ford GT's 315/40 19.
