[Z06] DIY - Steering Wheel Replacement (or side-spoke cover replacement)
#61
Air bag Light
So the directions were perfect. Took less than an hour. Only issue I have now is that the airbag light stays on. I know I disconnected ground and let it sit before disassembly. No issue with airbag connectors and no issues putting everything back. I reconnected the negative terminal, waited a few minutes and started the car up. Airbag light stayed on. Let the car run, took it for a quick drive,hoping it just needed to reset and it still stayed on. Anyone know if the dealer just needs to reset the computer?
#62
lifeislikeaboxofchocolats
Just did mine this week...followed this..not the first time I had airbag off but the complete wheel change took maybe 30 minutes..got lucky as no puller needed
#63
tommy9052,
I'd just recommend taking it to the dealership and having them reset the airbag light. Also, might want to have them take a quick peak to make sure something isn't actually wrong with the airbag.
Chevrolet Customer Service,
Justin
Justin
Did you ever get the air bag light switch off ? Just curious I want to do mine tonight but don't want an issue with the light staying on. if I have to bring it to the dealer to reset the light I'll just have the dealer put the wheel in to begin with. Thank you for your time. Tommy
#64
another great post by dreamin, very helpful during my SW swap. only thing i will add is 2009 and up went to torx screws instead of allen heads, needed to pick up a size 20 and 30 for this job. turning the wheel while pulling on it got it loose. thanks again.
#65
Wow! Thanks for taking the time and energy to post the photos and step by step instructions! I don't think I would ever do it myself, but I appreciate your effort.
#66
Thank you so much for taking all the time you did to do this write up! I just got done putting my new DSVettes wheel on and although had a similar problem with the generic wheel puller, I got it done all by myself.
Thanks from a mildly mechanically challenged girl! You made it simple enough even I could do it!!
#68
_"SCOTT"_
I'll go out on a limb and say that 100% of time a steering wheel puller is not necessary. Just loosen the center nut but don't remove it, if the wheel won't pull straight off, just gently **** from side to side until it comes right off.
One of the few mods I think are absolutely necessary for pre-'12 Corvettes...
#71
Super DIY
Thanks Dreamin. I was able to get my old wheel off and a new one installed in under an hour and thirty min. Thanks for the brillant write up. It made this update a breeze.
#73
Just did this mod. Took about 30 minutes. Everything went great except I ended up having my airbag light on the dash light up. I don't understand what I could have possibly done wrong. There are only two connectors for the airbag. One is pink, one is white. I plugged them both in and they clicked in place. They are not loose, they do not pull out.
The only thing I didn't do was replace the little yellow pieces on the airbag connectors. They would not fit in when I tried to reinstall them, and they started to bend when I forced them in, so I just left them off. Could this cause the airbag light to turn on?See picture below:
edit: It is those yellow clips. I have to go dig through my trash to look for them now. See this thread for reference: http://forums.corvetteforum.com/c6-z...leshoot-2.html
#75
I successfully and rather easily installed a 2012 steering wheel with red stitching on my 2008 C6. I love it! A definite upgrade from the stock wheel. The process took me about an hour and a half, though I'm pretty sure I could do it in 20 minutes now, given the chance. Super easy, thanks to these detailed installation instructions. Thank you so much, OP!
P.S. I rented a steering wheel puller, though I didn't end up using it. As others have stated, just loosen the main nut a few threads and give the steering wheel a few firm jiggles from each side. Eventually, I heard a "pop" and the wheel was loose. ... I was expecting the pop to be much louder, for some reason!
#76
Looks good. Yay thread revivals!
#77
Great thread! Swapped out the stock wheel on my 2008 for a 2012 suede one with blue stitching today, no puller needed. So much easier then my C5 was!
Before
After
Before
After
#78
Emerging Vendor
In my over 50 years of working on cars, I've yet to come across a steering wheel that needed a puller. Just back off the nut, then pull and wiggle - it will come loose. Just don't take off the nut first or you won't be happy with the results!
All you need is a flat ended 1/8" or 5/32" punch and a 21mm socket. It's a simple job you can do in a few minutes.
As others have found, this is a nice addition to the interior of your Vette.
