C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Whats this? rocks between body panels!
Old 08-13-2008, 08:52 PM
howardl
howardl's Avatar
Default Whats this? rocks between body panels!
Now that I have a lift and can do cleaning at eye level I found rocks/gravel in the gap between the rocker panel and the rear quarter panel just in front of the rear wheel! I had to remove the screw on the quarter panel inside the wheel well pull the panel out a little and use a small brush to get them all out. No paint danage yet but if it is left there I am sure it would. Looks like they get thrown up and in the gap between the wheel well liner and the quarter panel, I think the fix is going to be some black RTV to fill the gap? What do you think.. Any one else found this?
Old 08-13-2008, 09:06 PM
QIKSLVR
QIKSLVR's Avatar
Same thing on mine. I'm glad they can be removed as easily as that.
Old 08-13-2008, 09:08 PM
Hatdude
Hatdude's Avatar
If you use the search feature you'll find many posts on this.. even a "how to" to solve the problem using foam rubber weather-stripping.
Old 08-13-2008, 09:09 PM
ByByBMW
Support Corvetteforum!
ByByBMW's Avatar
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Pipedreams will probably post here but I will beat him to it. Try this link on his website and get rid of the rocks, http://www.nakidparts.com/id22.html
Old 08-13-2008, 09:26 PM
jnx911
jnx911's Avatar
I couldn't get the weatherstrip to work very well, so I used clear silicone and used an eraser from a pencil to smooth it out. Works well.
Old 08-13-2008, 10:23 PM
QIKSLVR
QIKSLVR's Avatar
Thanks for the link!
Old 08-13-2008, 10:40 PM
1-2-b-67L89
1-2-b-67L89's Avatar
Went to HomeDepot for the door/window adhesive backed foam weather stripping and placed between as per pipedreams simple instuctions posted by "bybybmw". You have to remove a few screws but it is not difficult and solves the problem with very little expense. Simple but it works
Old 08-14-2008, 08:42 AM
skudlw
skudlw's Avatar
Same here. The clear silicone keeps it all out.
To Whats this? rocks between body panels!
Quick Reply: [Z06] Whats this? rocks between body panels!
