C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Checkout our new Fan Control Switch....
Old 10-07-2008, 11:03 PM
southerncarparts
Supporting Vendor
southerncarparts's Avatar
St. Jude Donor '06-'07, '13, '15
Default Checkout our new Fan Control Switch....
Just launched....
Take complete control of your C6, Z06, or ZR1 coolant fan with our new Corvette C6 Fan Control Switch
This brand new Plug-And-Play control module installs under the hood, at the fan connector, and is designed to manually control the PWM coolant fan found on the 2005-2009 C6, Z06 and ZR1 Corvette. When the need arises to manually cool the radiator down, this module gives you complete control (high, low, and normal) of the fan with the simple flick of a switch. This kit can be installed in less then one hour, once you decide on where you want to place the control switch. This switch matches the style and look of cockpit switches used on all the C6 Corvettes.
Comes with easy to follow installation instructions.
Ordering info below.
Jim
Old 10-07-2008, 11:06 PM
drabe
drabe's Avatar
Any issues with the check engine light etc if the fan is manually turned on at a tiime when the ECU would not have triggered the fans?
Old 10-08-2008, 10:41 PM
southerncarparts
Supporting Vendor
Nope.....not at all.....
Jim
Old 10-10-2008, 03:57 PM
obzidian
obzidian's Avatar
St. Jude Donor '09
I had one of these on my camaro and it make a world of a difference when needing to get the temps down.
Bump for a good product!
Old 10-11-2008, 12:12 AM
Dirty Howie
Dirty Howie's Avatar
Old 10-14-2008, 12:14 PM
o6zo6vette
o6zo6vette's Avatar
can u run it with the car off like if u were at the track cooling it in the lanes before your next run?
Old 10-16-2008, 03:16 PM
southerncarparts
Supporting Vendor
Yep! Complete control...
Thanks,
Dave
Old 10-31-2008, 03:00 PM
dperretti
dperretti's Avatar
Has anybody installed one of these units yet? If so, how much cooler does it keep the coolant temperature.
Old 11-02-2008, 10:27 AM
southerncarparts
Supporting Vendor
Anyone?
I know we have sold at least 15 of them in the last 2 weeks..I am sure someone will post for you..
Jim
Old 11-02-2008, 11:17 AM
rws.1
rws.1's Avatar
Old 11-03-2008, 03:56 PM
Mark Ducati
Mark Ducati's Avatar
Simple plug and play apparently, my only question is.... how easy is it to fish the wire somewhere through the firewall?
Is there already an opening, or do I have to drill a hole for it?
Where are you guys mounting the switch? I'm guessing somewhere down low and left out of the way?
Old 11-04-2008, 10:59 AM
southerncarparts
Supporting Vendor
No holes needed....you route the wires through the upper door jam on the passenger or drivers side. You can mount the switch wherever you like. I have not installed it on my car yet, but am planning it for this weekend.
Thanks,
Jim
Old 11-04-2008, 02:00 PM
dperretti
dperretti's Avatar
Thanks,
Jim
Has anyone installed their's yet? I question the reliability of it, what kind of warranty does it come with?
Old 11-11-2008, 07:22 PM
dperretti
dperretti's Avatar
In stock and ready to ship!
Order here:
Thanks,
Dave
No feed back yet from anyone that has installed it and has put some miles on it?
Old 11-18-2008, 11:16 AM
southerncarparts
Supporting Vendor
Many people have installed it without any problems, and since it's a very quality piece we offer a one-year warranty on it.
Thanks,
Dave
Old 11-18-2008, 11:25 AM
sleeplessinseattle
sleeplessinseattle's Avatar
I installed it a couple of weeks ago. Works great. When I turn it on high speed it will bring down the temp about 20 degrees. I ran the wires under the oil tank and through the door jam as they suggested. I mounted the switch in the cigarette lighter hole in the console. The console comes out very easily. I indented the tabs on the side of the lighter recepticle and took the whole thing out. I then put a couple of rounds of electrical tape around the switch, just below the outside edge, so it would have a tighter fit when I pushed the switch into the cigarette lighter hole. Now the switch is invisible and I just flip open the ashtray door when I want to use it.
Old 11-19-2008, 02:16 PM
dperretti
dperretti's Avatar
Were you able to install the controller from the top or did you have to get to it from underneath?
To Checkout our new Fan Control Switch....
Old 11-19-2008, 05:34 PM
southerncarparts
Supporting Vendor
When you have time, post a pic of the install please.....Would love to see it
Thanks,
Jim
Old 11-23-2008, 08:07 PM
sleeplessinseattle
I will post a picture when I get back in town on Tuesday.
Old 11-24-2008, 10:54 PM
blitzu
blitzu's Avatar
A great product, works flawless, no codes, and easy to install! Highly recommended.
Quick Reply: [Z06] Checkout our new Fan Control Switch....
