[Z06] Oil Filter Question
I will say though, that I see very high oil pressures on my Z then I ever saw on my GTO's. 50 P.S.I. is at idle on the Z, where as the GTO only ever hit 50 if I was above 2k RPM.
I don't know if they changed the oil pump on the 09's to follow the ZR1, but that is a lot of pressure in the upper RPM range.
just my observation. right now, my 09 Z06 is running the same filter as the 08's.
