C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Where can I get a tach signal on a C6Z?
Old 04-14-2009, 06:46 PM
dpracing
dpracing's Avatar
Location: 11.13 @ 128.68 Bone stock on non stock tires.
Default Where can I get a tach signal on a C6Z?
Does anybody know?
Thanks in advance.
Old 04-14-2009, 09:20 PM
dpracing
dpracing's Avatar
Anyone?
Old 04-14-2009, 09:28 PM
Zip Corvettes
Platinum Supporting Vendor
Zip Corvettes's Avatar
It is pin 48 on the VCM, that is a white wire, circuit 121. That wire goes through the bulk head connector and into the plug in at the instrument gauge. It is still a white wire when it plugs into the gauge pod. If I am reading the schematic correctly it is connector 2 pin 5 in the gauge, just make sure it is a white wire.
Old 04-14-2009, 10:31 PM
rattt g
rattt g's Avatar
Originally Posted by dpracing
Anyone?
it's the green wire under the driver side cover it is in the middle
of the coil packs where the wires group together in the plug
Old 04-14-2009, 11:53 PM
BEZ06
Support Corvetteforum!
BEZ06's Avatar
What are you going to do with it?
If you're gonna run it to something under the hood, the info about coil packs or PCM are good.
If you want it for inside the car (shift light, data-logger) then you can tap into the white wire jabbot is talking about.
I wanted a signal for my Traqmate data acquisition unit and also for my progressive shift light. I spliced into the white wire going into the back of the instrument cluster. Here's a thread by Pipedreams that shows how to get into that area:
http://forums.corvetteforum.com/c6-c...many-pics.html
Scroll down to about the 11th picture and you'll see the connectors that attach to the tach and the speedo. He's holding the wire bundle for the speedo, but you can see the white wire for the tach signal in the wire bundle going into the connector on the left - it's right in the middle of the other wires.
Bob
Old 04-15-2009, 08:37 AM
dpracing
dpracing's Avatar
Anybody know which green wire it is?
There are 2.
Old 04-15-2009, 10:24 AM
BEZ06
BEZ06's Avatar
Take a look at this thread:
http://forums.corvetteforum.com/c6-t...006-vette.html
There are a couple posts with pictures of the connectors and pin#'s and wire colors.
It looks like the green wires are TPS, or MAP sensors.
Like jabbott said, the white wire going to pin# 48 on the PCM will give you a tach signal if you need one under the hood.
Bob
Old 04-15-2009, 10:36 AM
rattt g
rattt g's Avatar
it the green wire rite in the middle of the plug
Old 04-15-2009, 10:56 AM
Rob Willis
Rob Willis's Avatar
I took apart the guage cluster and tapped into the one going to the back of the RPM/Speedo/dash for my Traqmate, wasn't hard at all.
Old 06-11-2012, 07:39 PM
KLLRVET
KLLRVET's Avatar
good stuff
To Where can I get a tach signal on a C6Z?
Quick Reply: [Z06] Where can I get a tach signal on a C6Z?
