C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] How much does the C6 Z06 engine cradle weigh?
Old 05-05-2009, 04:27 PM
chazc6
chazc6's Avatar
St. Jude Donor '10
Default Does anyone know how much the C6 Z06 engine cradle weigh?
Does any know how much the C6 Z06 engine cradle weighs? or the C6 non Z06 engine cradle. Could you please tell me. I'm trying to compare. Thanks
Old 05-06-2009, 12:00 PM
chazc6
chazc6's Avatar
St. Jude Donor '10
Old 05-06-2009, 02:31 PM
426 Hemi
426 Hemi's Avatar
This is from the FAQ section. This discussion is about a probable magnesium rear crossmember---but they refer to the weight savings of the magnesium front crossmember (12.1 lbs):
"That rear crossmember is likely to be worth nearly the same mass savings as the front (5.5 kg = 12.1 lbs). The front crossmember/engine cradle is the first production part from the USCAR team (fast-tracked)."
Old 05-06-2009, 03:43 PM
robvuk
robvuk's Avatar
I might be wrong but I was under the impression that all C6's had magnesium engine cradles. Sorry I don't know the weight.
Old 05-06-2009, 03:47 PM
RichieRichZ06
Supporting Vendor
Support Corvetteforum!
RichieRichZ06's Avatar
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes on 597 Posts
St. Jude Donor '08
GM's site says my ship weight for that part is 10.79 lbs.
Old 05-06-2009, 03:49 PM
BubbaDuss
BubbaDuss's Avatar
My front cross member was cast in a helium rich environment. so it actually floats..
Nice work with the 12.1 pounds, sure beats my GTO's 52 Pounder :-(
Old 05-06-2009, 11:40 PM
chazc6
chazc6's Avatar
St. Jude Donor '10
Thanks guys
Old 05-07-2009, 06:14 PM
dpracing
dpracing's Avatar
Location: 11.13 @ 128.68 Bone stock on non stock tires.
Magnesium engine cradle is unique to the ZO6 and the ZR1.
Old 05-07-2009, 06:24 PM
robvuk
robvuk's Avatar
I just looked it up, you are correct. Here is what I found.
"Compared to its aluminium predecessor, the 10.85-kilogram magnesium engine cradle provides mass savings of 30 to 35 percent."
That's roughly 24 lbs. so I guess the aluminum one was 36 lbs.
To How much does the C6 Z06 engine cradle weigh?
Quick Reply: [Z06] How much does the C6 Z06 engine cradle weigh?
