[Z06] PCV Delete on an LS7
I would like to know if you could "T" the valley cover port into the lines coming from the valve covers and just cap that port on the TB. The much longer line from the bridge to the oil sump should not flow much oil and one could even increase the length of that line to help more.
I guess you would lose your vacuum this way and it would just be a excess pressure relief system rather than a Vacuum assisted one.
Okay, didn't think about that. I wonder if just increasing the length of the line from the valley over to the TB would help if I could maintain a slight elevation gain to get the oil running back. A 'cooled' catch can may also be a good idea, but where to put a cooling system for it? Condense the oil out of the air.
