[ZR1] ZR1 Headers
Full size member
Putting headers on your ZR1 without a tune will decrease your power. The extra flow you gain by adding the headers will decrease your boost pressure. You will need to put a smaller pulley on to compensate for the loss of psi.
Full size member
From what i've heard the headers will decrease the boost pressure but in the end gain hp. To really take advantage of the extra flow, yes a tune and smaller pulley would be great.
Here is what i've seen
A.R. Headers Pics And Dyno Results!!!
Incorrect.
Please don't confuse decreased boost with decreased power. If exhaust scavenging improves (as it does with headers) boost will decrease, but since you have actually improved the engines volumetric efficiency, power will increase. A proper tune is necessary, of course.
By your logic, I could install a 1.5" catback on a supercharged car and double the boost it makes at the manifold. Will that double my horsepower?
xxDevilDogxx (03-04-2017)
Full size member
Full size member
Well then which one is it? A tune or a smaller pulley?
Full size member
Whatever, you don't have any room to talk. I own one of these cars and so do two other friends of mine. We have experimented with all of them and I/we know what happens when certain items are added to this car. Experience with this paticular vehicle overrides your comments.
1 Post
Actually - forced induction doesn't change depending on the car, and it is not necessary to own a ZR1 to understand the concepts involved - it is all the same. The Doctor's comments are not only valid, but 100% correct. Headers will definitely make more power with a tune, and that power will come at a lower boost level. If you drop a pulley size, and return to the previous boost level, then you'll make even more power at the same boost level as pre-header. Of course, the tune must always be adjusted accordingly.
You do realize there are more variables at play here than just headers....while headers without a tune may not do much, I guarantee there is some power to be had there.
The REAL issue is that you are confusing less boost (after adding headers) with less power. Less boost is a function of decreased backpressure and therefore less restriction. BOOST and FLOW are two different metrics, and your understanding of this has NOTHING to do with ZR1 ownership.
okay I am not a tech guy at all, but I need some help in understanding correctly what this thread is discussing.
I have a 2009 ZR1.
The previous posts have different opinions on headers.
If you don't get any HP gains why would you put them on?
Would you have to change the pulley and thereby increase the boost to have any benefit?
Would additional heat soak cut down your power more with the pulley change?
In doing so can you still run on pump gas?
Thanks for any info you can give.
I have a 2009 ZR1.
Premium Supporting Vendor
1BADZR1, We've never seen a power loss with headers on a supercharged GM, Ford or Chrysler product. Our testing HP gains with 2lbs. less boost. Your friends ride saw no gains though he lost boost. Anyway you look at it, it is a vast improvement. Replacing the lost boost I guarantee you will be worth a ton more power. BTW, Innovators West I'm told is working on a lower pulley/dampner that'll put that boost back in. You guys may want to look into it.
Nick
Nick
Should I change the cats or what I have to do?
Boost is an indicator of back pressure - a measure of restriction. Dropping "boost" from the header swap just means your engine is moving more air without the same restriction in place which is the whole point. This is increased efficiency. But you would need to tune the engine for this and as mentioned above you can pulley up the blower for even more air movement at the previous "boost" level.
running kook's with catless x-pipe before tune on dyno jet it showed 513rwhp after tune 566rwhp running on 98 octane
