[Z06] **Offical LG GT2 Corvette Rebuild Thread**
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Hi guys,
Everyone remembers the scary and horrible fire at Long Beach with Boris behind the wheel of our GT2 Corvette. I am happy to announce that the car is going back together now and will make it's first appearance at the Corvette's of Carlisle show then onto Watkins for it's first shake down runs before Atlanta.
Fire!!
Blasted and Cleaned Frame
Frame being Primed
Frame being painted
Frame complete in red
Front Suspension mounted
Rear suspension going together
Center Switch panel stack
Dash rebuilt and ready for install
Pedals, Steering column, and shifter being installed
Louis and myself are going at it pretty quickly now, so I will be updating the thread with new pictures as the car comes together so STAY TUNED!!!
Fire!!
Frame being Primed
Frame being painted
Former Vendor
Saturday Morning Update:
Rear Firewall Installed
Wiring Harness and Brake Reservoirs Being Installed
Wiring Harness and Computers Being Installed
Steering wheel with controls Mounted
Former Vendor
If I was at the track, doing this before a race, 12 guys, 24-48 hours strait it could be done.
Fastest Ive ever assembled a race car was 30 days, I might beat that with this car, only because it has been together before, but Im trying to not work too late
Now that some time has passed I hope it wont hurt to ask. Did any of you guys joke around some point after the accident that a car with flames painted all over it caught on fire?
Former Vendor
Sunday Morning Update...
Rear Spindles assembled with half shafts
EMCO Transaxle with mid plates attached and ready for Install
Under Dash wiring and plumbing ready for dash install
Under Column area ready for Dash Install
Electronics panel including; PDU, Bosch ECU, and Motec Data
Keep nocking it Lou, can't wait to see the finished car @ Road Atlanta. Who's going to share the driver duties with you for that race.
Mike P.
Mike P.
Maybe I'm way off base (I'm certainly not a metallurgist) but did you guys have to have the frame inspected in any way (x-rayed, tensile strength tested, etc.) after the fire? I was just thinking that the heat would have damaged the alloy composition to the point where the properties of the metals would be compromised/unsafe. Anyway, great looking build notwithstanding my nanny-state mentality.
Christian
Christian
Former Vendor
Christian
Christian
It did not get so hot that metal was compromised. The fire lasted 35 seconds, most of which was fueled by the compromised fuel line that lit the fire. If I can scrape paint off, its fine
Former Vendor
Monday Afternoon 7-20-09 Update
Dash Installed with Center Switch panel
Louis attaching Dash harness to car Harness
Center Tunnel Heat Shielding Going In
