[ZR1] 2010 ZR-1 0-60ft with LC?
while we are on thie topic of LC, what about the PTM system GM was talking about? does the 2010 Zr-1 come equipped with the PTM system? From what I recall the 09s dont have it installed
I meant that the computerized LC from other manufacturers also controls the release of the clutch, not just the application of throttle. On many higher-end cars, including Ferrari, the implementation of LC controls both the clutch and throttle.
In order to get the fastest launches, good drivers will slip the clutch in a controlled manner. Just the right amount and you'll get a great launch. Too much slippage and the clutch will overheat, not enough and the engine will bog.
Good drivers know just the right amount and control the release of the clutch, i.e. "modulate" the clutch pedal, in order to do this manually. With more sophisticated LC systems, the electronics do this for the driver.
Hope that helps.
Hope that helps.
I believe this is accomplished with the auto/manual gearboxes and DSG that don't have a manual clutch.
