[Z06] Tire pressure sensor question
I have custom wheels on my Z and the tire pressure sensors are banded to the front wheels.
I had to have one replaced and the tire shop cut the valve stem portion of the sensor off because the sensor wouldn't fit flush on the hub of the wheel. Now they can't get the sensor to pick up with the scan tool.
Will cutting the valve stem portion off ruin the sensor?
Try aiming the TPMS tool through the rubber sidewall at various places on the tire. (The RF will not go through the alum well.)
If you break it down again, mark the spot where it is located. When they are in the original hole it is visable, but with it is banded on the inside it is pretty hard to figure out where it is.
Wil Cooksey #256
