C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Wheel/Tire vibration problem fixed **
Old 12-01-2009, 07:54 PM
augydog
augydog's Avatar
St. Jude Donor '08-'09
Default Wheel/Tire vibration problem fixed **
First, I would like to thank everyone for their help on what the problem could be.
Took the car to the only place that I would allow any touching of my wheels .
Had all 4 wheels checked and tires road forced re-balanced on the Hunter machine.
Findings:
Each front wheel was out of balance by 1/2 ounce. (One front wheel didn't have any weights at all and needed the 1/2 ounce to bring it into balance.)
One rear wheel had the weight shifted by 12 inches. The weight was removed and the same amount (1/2 ounce) was put back on in the correct location. (I guess some aggressive driving caused it )
The remaining rear wheel was fine, and balanced as is.
Drove the car home, smooth as silk.
augydog
Old 12-01-2009, 08:00 PM
QwikC
QwikC's Avatar
Now you can be "certain" about the weight(s), glad it was the least of possible problems. If only everything could be so easily resolved.
Old 12-01-2009, 08:16 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Good job, now you can enjoy your ride.
Old 12-01-2009, 11:00 PM
Marc Lefebvre
Marc Lefebvre's Avatar
Great news, now let's see if thet did a better job securing those wheel weights this time. Giversumore. Marc L.
Old 12-02-2009, 12:07 AM
GMuffley
GMuffley's Avatar
Its not easy to find shops to work on the Z wheels without damage.
Old 12-02-2009, 05:25 AM
Zoxxo
Zoxxo's Avatar
Excellent!
(the weight shifted? My weights are stuck on with adhesive so 'shifting' would seem more than a little unlikely.)
Z//
Old 12-02-2009, 06:20 AM
Joe C5
Joe C5's Avatar
Originally Posted by Zoxxo
Excellent!
Z//
However, I wonder if the tire would "slip" (rotate) if one was too agressive before the lubricant they use to mount tires dried out and the tire was fully "stuck" (hence why some top fuel cars used to use fasteners to keep the tires from slipping on the rims?)...
Old 12-02-2009, 02:30 PM
augydog
augydog's Avatar
Excellent!
Z//
Yes, the tire moved on the rim that far.
The weights were glued down good.
I'm marking the weight locations on the rear tires, so I'll know if they shift again.
augydog
Old 12-02-2009, 02:56 PM
Minkster
Minkster's Avatar
Old 12-02-2009, 04:30 PM
Zoxxo
Zoxxo's Avatar
augydog
Ah! So my suspicion was correct! Cool (I guess )
Glad you figured it out.
Z//
Old 12-02-2009, 04:31 PM
MachAll 2005
MachAll 2005's Avatar
my guy that mounted my last set of tires told me to take it easy for a 100 miles or so or they could slip on the rim. I put a paint mark on the tire aligned with the valve stem to make sure they didn't move.......3500 miles later all is ok.
Old 12-02-2009, 05:40 PM
augydog
augydog's Avatar
Great Info
Too bad mine didn't tell me that.
augydog
To Wheel/Tire vibration problem fixed **
Quick Reply: [Z06] Wheel/Tire vibration problem fixed **
