[Z06] Super Savings on Combo Packages, Front Plate Bkacet & M2W
Save up to $53 on one of the hottest Combo Package offers ever!
We have 20 of each offer ready to ship (other sale items can be found at the sale link)
1. Our best selling Top Flight Reproductions Removable Front license Plate Bracket and the Original Nakid Parts Mild2Wild, the #1 selling wireless exhaust controller for the C6 = Plate Bracket + Mild2Wild
C6 Combo package #1= Normally $199 for the two / Group purchase = only $160 (save $39)
Z06 / ZR1 / GS Combo Package #2= Normally $209 for the two / Group purchase = only $169 (save $40)
2. Add the original corvette splash guards for only $49 (set of 4, no drilling and 100% removable) = Plate Bracket + Mild2Wild + Splash Guards (C6 only)
C6 Combo Package #3= Normally $252 for the three / Group purchase = only $199 (save $53)
SALE LINK ORDER NOW!
The Top Flight Reproductions C6 front license plate bracket is the best looking mount available. It follows the contour of the front bumper. Installs easily without lifting the car. Requires no drilling for attachment like some others do. Our bracket is priced considerably lower than other after market solutions and is made in the USA .
The original Mild2Wild - “0” ZERO battery drain, start in either Mild (closed) or Wild (open) and has just the right function you need with a 3 minute install…just Mild2Wild at your command!
Simply install the unit, program the homelink (cars built after 10/06 may not have homelink) so you can use the provided mini remotes and you now have taken full control of the Bi-Mode exhaust. MILD (quite) when you want and WILD (aggressive) when you need it. Lets face it, much of your driving is under 3500 RPM so why not have that aggressive sound when you need it the most. Switch it any time running or not. The system is also designed to maintain the last know setting so the car starts up in the same position it was shut off in.
Some suggest it need to be easy to reach like your traction control. In reality, the exhaust is generally left in the wild position and the only need to access the switch is when you need to kill the drone on long trips. It certainly is not like the traction control that may need to be switched on or off in an emergency.
The 5 MIN Wireless Install (most do it in 2min)
Use your HOMELINK (cars built after 10/06 do not use HomeLink) or THE PROVIDED MINI REMOTES. Some mounting options
More on Mild2Wild
Is the license plate bracket color matched?
If not, do you have a pic of the unpainted bracket on a LMB Z06?
my Z already has a M2W, what is the price of the bracket only?
Al
Al
http://www.topflightrepro.com/
Do you have any detail pics of how you remove the front plate?
Is this an easy on and off?
http://www.topflightrepro.com/corvet...brackets.shtml
