C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] LS7 Valve Size Question
Old 01-12-2010, 05:44 PM
BgBoost1
BgBoost1's Avatar
Default LS7 Valve Size Question
LS7 Cylinder Head: I need to know the Overall Length and the tip length of the Intake and Exhaust Valves that come from the factory.
Does anyone have this information?
Thanks in advance!
BgBoost1
Old 01-13-2010, 04:50 PM
BgBoost1
BgBoost1's Avatar
Anyone?
I can pull some out and measure them, but I thought there would be an expert on here that would know the size for sure....Jason?
Old 01-14-2010, 02:32 PM
BgBoost1
BgBoost1's Avatar
Bueller..........Bueller.............Bue ller............Anyone?
Old 01-14-2010, 06:10 PM
Gannet
Support Corvetteforum!
Gannet's Avatar
St. Jude Donor '06
Manley lists the following in their catalog.
Intake: 5.200" LOA, 0.300" tip
Exhaust: 5.230" LOA, 0.290" tip
No guarantees that's the exact same as stock. For one thing, the stockers use a lash cap on the intake.
Old 01-14-2010, 07:14 PM
BgBoost1
BgBoost1's Avatar
Gannet - Thank You! I checked Del West, Ferrea, Xceldyne, and Rev, and didn't think to check the old standby Manley.
THANKS AGAIN!
BgBoost1
Old 01-15-2010, 10:11 AM
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
I measure 5.125". That does not include the lash cap.
The official GM spec is 5.123" +/- .005"
__________________
Contact:
(e) zach@katechengines.com
Old 01-15-2010, 10:15 AM
Katech_Zach
Those are probably steel valves with no lash cap which explains why they are .075 longer (to make up for the lack of a lash cap).
Old 01-15-2010, 10:37 AM
BgBoost1
BgBoost1's Avatar
Jason,
Thanks for the specs, I appreciate it! Is that for Only the Ti Intake Valve? I would assume that the exhaust valve would be a bit longer (without the use of the lash cap).
Do you have a measurement of the exhaust valve?
Thanks again!
BgBoost1
Old 01-15-2010, 10:48 AM
Katech_Zach
Originally Posted by BgBoost1
Jason,
Thanks again!
BgBoost1
The book shows the exhaust valve is the same.
Old 01-15-2010, 11:31 AM
BgBoost1
BgBoost1's Avatar
Jason,
I have a Brand New GM LS7 Cylinder Head in my garage, I will pull out the Intake and Exhaust Valves this weekend and measure them, just to be 100%. I will let you know what I find out!
Thanks again!
Joel
To LS7 Valve Size Question
Quick Reply: [Z06] LS7 Valve Size Question
