[Z06] Checking oil in a Z06
I traded UP from a C6 to a Z06 and have this question - sounds stupid - "How/When do you check the oil" AND do you keep it to the 3rd (top) "dot/hole" or in the middle somewhere (less pressure):
1. Check when it is hot?
2. Check when it is cold?
Check your oil regularly just like you would/should on a normal vehicle. There are instructions in the manual but here yah go. Start the car and let it run for a few minutes unless you were just driving around. Shut car off and wait for at least 5 minutes but no more than about 10 minutes I would say. I think the 3 dots are the operating range but try to keep it at the 3rd (full) dot.
BTW - I used to drive 911s with a dry sump system, and they had an oil level guage on the dash. It worked great. Don't know why Chevy can't do that...
z51vett
Larry Myers (07-04-2020)
Should I be concerned? Also what if the dealer used dino oil? I bought the car pre-owned in Sept and of course I asked and was ASSURED they used Mobil 1 5-30 but after just 2600 miles my Oil Life monitor is down to 30%. On my 06 Z51 (even tracked) I managed 7500 to 9000 miles before it got that low. Could DINO OIL be causing my HIGH PSI??
Tom
_"SCOTT"_
Checking Engine Oil (Z06 Only)
It is a good idea to check the engine oil level every time
you get fuel. In order to get an accurate reading, the
oil must be warm and the vehicle must be on level
ground.
The engine oil dipstick handle is a yellow loop. The
dipstick is located on the dry sump engine oil tank. See
Engine Compartment Overview on page 5-14 for the
location of the dry sump engine oil tank.
Z06 models have a racetrack-ready dry sump engine
lubrication system. This high-performance system
operates differently than a standard engine lubrication
system and requires a special procedure when checking
the engine oil level. Follow this procedure closely
when checking the engine oil level.
The engine oil level must be checked when the engine
is warm. Cold oil level in the dry sump tank may not
indicate the actual amount of oil in the system. With this
system, engine oil is contained in an external tank,
separate from the engine. Under normal operating
conditions, the oil pan under the engine does not store
any oil. If the vehicle has been parked for an extended
period without the engine being started, some oil
will seep back into the oil pan, reducing the amount of
oil held in the dry sump tank and there could be no
engine oil at all showing on the dipstick. This is normal
since the dipstick is designed to read engine oil level
only after the engine has run long enough to reach
normal operating temperature. Do not add engine oil
based on cold engine dipstick readings. The engine oil
level on the dipstick will also be inaccurate if checked
while the engine is running.
1. To obtain an accurate engine oil level reading,
warm up the engine to at least 175°F (80°C).
Cold oil will not give a correct oil level reading.
2. Once the engine is warm, turn off the engine.
Checking the oil while the engine is running
will result in an incorrect oil level reading.
3. Wait at least five minutes (but not more than
20 minutes) to allow oil to drain and settle in
the engine.
4. Remove the dipstick from the external engine oil
tank and clean it with a lint-free paper towel or a
cloth. Re-insert the dipstick into the external oil tank,
pushing it all the way in until it stops.
5. Remove the dipstick from the oil tank and read the
level on the cross-hatched area. Oil levels that fall
in the cross-hatched area are normal.
When to Add Engine Oil (Z06 Only)
If the oil is below the cross-hatched area at the tip of
the dipstick, add at least one quart/liter of the
recommended oil through the oil fill cap opening in the
oil tank. This section explains what kind of oil to
use. For engine oil crankcase capacity, see Capacities
and Specifications on page 5-103.
See Racing or Other Competitive Driving on page 4-15
for additional information on engine oil.
Notice: Do not add too much oil. If the engine has
so much oil that the oil level gets above the
cross-hatched area that shows the proper operating
range, the engine could be damaged.
See Engine Compartment
the location of the
external engine oil tank
and fill cap.
Be sure to add enough oil to put the level somewhere in
the proper operating range. Push the dipstick all the way
back into the oil tank when you are through.
_"SCOTT"_
While I religously check my oil and even read the manual, I have noticed VERY HIGH OIL PRESSURSES. At times over 90 PSI and even at idle and light throttle it's over 50/60 PSI.
Tom
Tom
Read the manual
NO
Sometimes, people on here offer extra information that the manual does not. Hell, most of the time, people on here have better solutions to deal with some issues that Chevy say are a must.
I guess each of you use the EXACT recommended lubricants, solvents, and cleaners that THE MANUAL recommend.
Give it a break. Especially when a newbie comes on here and sees how almost everyone has suggestions to "MODIFY" how we deal with our corvettes. Then they want to know the "REAL DEAL" about something as basic as an oil change.
Concerning an oil change, look it up in a search here. You will find NUMEROUS different suggestions that do not exactly follow the manual.
There are a million examples of modifications to what the manual suggests on here. Why preach it?
This site is for entertainment and information. I get more entertainment and information on here from a post where a newbie asks a question than from a Senior Member who only suggest to read the manual.
Newbies . . . You can ask ***ANY*** question on here. You will get the answers that you need from concerned posters. Just keep in mind that you will also get some responses that offer ***ZERO*** information pertaining to your specific question.
oil
[QUOTE=Joopman;1572939159]So, EVERYONE on here does exactly what the manual says?
NO
Newbies . . . You can ask ***ANY*** question on here. You will get the answers that you need from concerned posters. Just keep in mind that you will also get some responses that offer ***ZERO*** information pertaining to your specific question.[/QUOTE
completely, we were all newbies at on time.
NO
jbeezy (10-17-2020)
With knowing GM increased capacity on 09+ Z06's due to oil starvation concerns, I always run my oil level to the top of the cross hatched area (all 3 holes covered). Remember if your on the low end towards the bottom of the cross-hatched your already running nearly 1 quart low!
As stated I keep mine full at all times, I've noticed a little less then 1/4 quart usage every 3-4k miles. This method has worked for me, never noticed any symptoms of overfilling ie: oil in the intake.
I run mine down to 0% ..... thats what the 0% is for.
I notice that hard track day does not move the oil monitor.
But lots of stop n' go and cold oil temps drop it quickly.
At the rate your monitor is indicating it looks like you should get to 5K miles which seems reasonable for synthetic.
DH
DH
NO
NO
NO
NO
