[Z06] Katech tests Halltech's new intake systems on the engine dyno
Supporting Vendor
St. Jude Donor '09
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
www.halltechsystems.com
262-510-7600
For service email:
Jim,
What are the weights of the KB CF112, KB II and KB I? The carbon work looks really good. Any chance we could get them to make us some ultra light CF (not cosmetic but real race piece) lift off hoods that look similar to our stock hoods? You know, no bulges, scoops, vents, inner panels or mounting hardware. You know, something that looks pretty stock but around 4-5 pounds max. What do you think? Something to offset the weight loss in the rear for the Akrapovics.
Gary
Gary
Supporting Vendor
St. Jude Donor '09
Jim,
Gary
Gary
This is not wet laid crap over fiberglass, it is the real deal with pre-impregnated-vacuum bagging/oven layups.
The differenct between the carbon fiber and plastic is very slight and not worth the discussion.
Jim
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
I suspect the comment concerning warranty denial has to do with any changes to calibration (which I understand from your website and various threads here is required for the CF112 version). There have been a number of comments on the forum concerning GM's policy reference reprogramming of the factory tune being automatic grounds for denial of engine warranty claims. If there is some clarification or explanation that you could put forth, I'm certainly not alone in being very interested to hear it.
Premium Supporting Vendor
No.
He's saying that he's never had a warranty claim denied for simply an intake. A tune could potentially void warranty.
Supporting Vendor
St. Jude Donor '09
So from the onset of its development, we went for the ultimate intake, and have an SCT X3 Handheld tuner for those that track their cars.
The Super Bee CF112, with mild tuning to the MAF code puts +33 RWHP to the tires, which makes the track tune pretty tempting. The SCT X3 keeps the stock tune on the ready, so when you decide to reinstall the stock setup you can reflash back to stock.
Jim
Thanks for the clarification.
Good to hear since I have an original KB installed
He's saying that he's never had a warranty claim denied for simply an intake. A tune could potential void warranty.
To Halltech or Katech:
I have seen graph comparisons swapping intakes on the LS7. It would be helpful to see graph comparisons swapping intakes on a stock LS3. Also, the A/F ratio showing the affects of the swap. LS3's are known to run rich at WOT. It would be interesting to see how the ECM will adjust to the changes in intakes.
BTW: I have the original KB and Beehive Shroud with the two open shroud ports for cold air. The KB is a quality product and easy install!
#35
Supporting Vendor
St. Jude Donor '09
Chances are, the actual dynos might be long gone, but I will look. I know the CF112 added =15 HP
I will keep digging. I can tell you that our intake was the standard bearer for many years at Katech, and many other high end performance shops. They still are.
https://www.halltechsystems.com/category-s/84.htm
#40
