[Z06] oil filter question?
getting ready to do first oil change (finally got the ramps made to go over my lift). had to go to walmart b/c all the other car places were closed. anyways i picked up a fram. part # XG10060 is it any good? or should i bring it back and get something from autozone? thanks
Fram filters are ok but as for me I use Mobil One oil filters in my Z just like the oil. You can't go wrong using Mobil One Oil filters
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
IMHO, I would never use a Fram filter. There are oil filter research papers that can be found on the web by independent investigators that will explain why. On a daily driver, it will likely be okay. The minimum required quality has to be at least a Delco PF48 IMHO. I frankly don't think that any Fram measures up to the AC Delco filter line. I use the premium Delco Gold UPF48R myself. Mobil 1 and K&N filters are good as well.
The minimum filter I will use is the WIX 57060, but I prefer the Mobil1 M1-113 or the K&N HP-1017 in my 09Z. No way will a Fram ever be used on any of my cars.
I like the K & N as well. Has a handy stub on the end for a socket to either tighten or loosen. Nothing against Mobil 1 filters but I tried on on my C5 and couldn;t get it to quit leaking around the seal. Probably a fluke but changed to K & N and had no problems.
Premium Supporting Vendor
I sell many UPF48R's. Should you be interested in those, I'd be happy to help you out.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
trouble needlessly.
