[Z06] 2009 Z06 Halltech Killer Bee & Hive fitment / CEL
2009 Z06 - Looking for feedback related to Halltech Killer Bee and Bee Hive installation.
1) Are CEL issues common with this installation?
I've checked for tightness of MAF sensor. I've also researched CAI related CEL and there are vague posts out there..One rather direct thread references a Service Bulletin (08-06-04-040) about the fitment of CAI "This condition may be caused by a gap between the upper radiator air baffle and the bumper beam combined with some beam holes." I did ask the deal about CAI intake and they said it's fine and doesn't void the warranty (assume no cutting).
2) How about fitment? I wasn't thrilled with the fitment of the Bee Hive. Is some Dremel tweaking necessary? The filter 'neck' didn't fit real well over the top of the radiator housing. There was some binding/flexing of the silicone attachment to the throttle body. Perhaps this is why it is silicone and flexible but the bellows of the stock attachment now make very good sense for fitment at least. The Bee hive was also binding/buldging on the top of the filter 'neck' between the front of the car where the hood mounts and the filter neck.
The sides of the bee hive were binding on the radiator shroud.
Any experience with fitment or CEL is appreciated.
Fitment on mine was good; however, the beehive needs a little finess during installation. I would make sure you push the unit down flat to eliminate any sloppy fit. Also, I added a little adhesive to the weather stipping to make sure it would not come loose. It has provided outstanding results at the strip.
I've got that setup and have never had and check engine lights. The behive is a different story. It didn't fit right when I installed it. I also thought it should be sealed a little better(there were gaps everywhere.) So I did some cutting and tweaking to get it to fit perfect. I also used weather seal around the whole thing. I cut the opening in the top of the behive and used more rubber seal so it fits nice and tight around the intake tube. I also used left over pieces from the Exotic Vette insulation kit and covered the underside of the behive. So after all that I've got the air filter sealed off from the engine compartment so it should be breathing nothing but cold air.
Thanks for the feedback so far! I'll add these thoughts for feedback also
I was a bit hesitant to cut the bottom of the radiator support for the 'RAM air" affect. I did however notice that there isn't much air intake area in that enclosed space once the bee hive seals the top and side area (without bottom cuts made).
I'm wondering, does the NACA duct provide enough volume of air to satisfy the intake/throttle body system without the cutouts?
Also, I noticed a high pitch squeal from the engine when I accelerate quickly after the killer bee/bee hive installation. I assume this is at the point where the throttle body is just beginning to open and the air is rushing (whistling) as it rushes by the plate. Since the filter is less restrictive and more open (well inside the bee hive) you can hear this audible whistle/squeal.
Do others notice the whistle/squeal? If not, this may be a leak at the throttle body connection and the source of the CEL....
Thanks for your inputs!
I would get ahold of Jim Hall from Halltech on this. I'm sure he can rectify any issues you're having with the Bee and hive.
Saw this pop up and thought I'd respond with updates. I did speak with Jim Hall. Jim explained that they have installed this system on many Z06's and he's confident it fits with the right installation process. It fit well enough with just a bit of trimming in my application and I'm OK with that. There might be enough variability in spacing/mounting that makes for some onsite adjustment necessary.
I did get both the long strip for the front hood seal and the two rear seals.
The 'intake tube' does want to 'ride up' based on the bend (or lack of) at the connection to the throttle body and the arc of the intake tube itself. The filter connection also can cause the beehive to raise up as it might hit on the filter if the filter is mounted too high on the intake tube. This is what Jim was saying causes the most issues. The filter is mounted too high on the intake tube. You might need to push the filter down more on the neck so the beehive does not push up as much and contact the hood. From what I understand this (shape and tube length at filter mount) are some of the adjustments made to the new Beehive II.
I still do get a high pitch whistling that is very noticeable at lower RPM (partial open throttle body). I'm quite certain that is simply the throttle body taking a big breath of air. One guy asked if that was SC whine?? Uh no just whine
After that initial CEL, I have had no additional CELs. I discussed the CEL with Jim as well. He was confident that the CAI had not caused a CEL based on the many installations they have. There is always a first time but I felt reasonably reassured. I did start the car one time with the MAF not mounted into the new CAI but didn't see a CEL during that start which was only for a few moments. That could have caused the CEL on the next start from what I understand. Then, it was simply a matter of resetting it which I did via unplugging the battery. If you are getting it repeatedly, read the code to make sure it is associated.
I just installed the bee-hive and killer bee as well and I am having the same exact results. I have now gotten two check engine lights after carefully checking and re-checking the connection points. I noticed I have to sort of bend the intake down to close the hood before I installed the bee-hive. I also have the super high pitched whistling noise, I had it with my previous K&N intake which was part of the reason i bought the killer bee in the first place. I also didn't get any weather stripping for the front part of the beehive by the bumper. In the video it shows the really long strip for the front, but I only got the two strips for the back. Is this standard now?
I will admit the bee-hive did take some finesse to get in place but once see it has been fine.
Would love to hear what you conclude as I just got another CEL lol.
Supporting Vendor
St. Jude Donor '09
This issue is resolved completely with the new Killer Bee II.
We actually put a note on our new Killer Bee II hose clamp, not to tighten that clamp at all, since the hose itself is wrapped around that end so tight that a hose clamp becomes unnecessary except to look complete.
Jim Hall
Supporting Vendor
St. Jude Donor '09
That is why it went away. Once you installed the MAF, that eliminated the giant hole, correcting the code.
Thanks for the update. Disconnecting the battery will reset long term fuel trims, but it will not delete codes in the computer. 40 on off cylcles without the same code failure will erase the codes automatically, or a simple handheld like our new SCT X3 tuner will also read and delete codes permanently.
The whistle is from the throttle body, not the intake. It is easier to hear with the low restriction filters. I have heard this comment for 12 years now.
Thanks!
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
www.halltechsystems.com
262-510-7600
For service email:
No whistling, fitment, or issues with mine. Beehive was a pain to get on the first time but fit good and no issues. Logging intake temps without anything cutout shows 4-5 degrees over ambient cruising around. Car made 490rwhp on the dyno with LG headers, haltech with beehive and a tune.
Supporting Vendor
St. Jude Donor '09
Now I know why you call yourself Unreal!
Halltech rocks!
Jim I just can't believe how much better the car responds to throttle input. Not to mention as I posted in the other thread, I feel like there is a significant increase in power in the 2000-3000 RPM range. Not saying it isn't all the way up, but wow what a difference this aspect makes in daily driving!
Supporting Vendor
St. Jude Donor '09
One state away. I was just down to Chicago, IL Saturday and Sunday. You are right, I would have personally delivered the grommet to help you install the system. I have driven to IL before to deliver systems.
I take full responsibility for forgetting to drill one hole. Please accept my apology.
You should not have the hole in the connector hose. That will not work. I would be happy to replace the bridge with one that I have drilled and put a grommet in, along with a new hose.
"call me". 262-965-4300
Jim
Jim
Supporting Vendor
St. Jude Donor '09
Thanks,
Did you get the Carbon Fiber Super Bee or Killer Bee II in plastic?
The Super Bee CF112 does not come with a hole in the carbon fiber. We recommend that only qualified shops that can tune and install this system do the work, which you probably had.
The PCV, is not a PCV since it does not vent the crankcase. It is a breather tube for the Dry Sump Canister, which can be routed to the filter with the nipple provided in the package. That is the recommended placement by Katech Engine Development and the folks that build the aftermarket Dry Sump Systems.
Our goal was to eliminate the turbulence from the hole in the bridge right before the throttle body for a "no obstruction to flow" intake system.
Jim
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Its clear that Jim Halltech will do whatever is necessary to stand behind his products 1000%, and you just can't beat that type of customer service which is getting harder and harder to find these days!
