[Z06] **Z06 Muffler Mod with pics**
Just finished modifying my mufflers last Night,waiting on my headers from the jet coating..... so I don't have any sound clips for you guys but for now here are some pics of my buddy doing work
btw if anybody in the central California area needs this done just PM me
I used this template posted by another CF member to make my measurements,again thank for the great pic
Now for the dirty work
3 inch pipe cut in half
magnet holding both pieces in place
I had the mufflers painted in Gloss Black High temp paint
OwensRacing (05-03-2018)
Sweet, this is one of the better "How To's"..... Same question as above did you re-install the batting??
This mod seems to be catching on.. I'm in the process of getting a quote from a local exhaust shop.
Tom
Tom
Cruise-In VIII Veteran
St. Jude Donor '06
Outstanding write up.
These mufflers aren't stainless steel are they?
Nothing special as far as welding goes?.
I am an expert at welding aluminum, not much steel experience, but I'm gonna do this in my shop. I love to learn new things.
Tim
Tim
He used a cutoff tool to cut the muffler open. It is a round abrasive disc.
How did they weld the back side of the pipe? Were 7x7 holes cut into both sides of the muffler so it could be welded all the way around, or did they only weld as much as the could reach from the one side?
U.M.
U.M.
Underachieved (05-04-2018)
Sorry guys forgot to mention that we did cut both sides of the muffler, so then we can weld both sides of the pipe.Not really necessary but we had lots of time and it was great learning how to weld
nice post and pics say 1million words.
nice improvement in sound but probably no improvement in performance.
Nice! Thanks for the pics!
I did reinstall the fiberglass packing back inside
Nice.... If you can weld aluminum then this is a piece of cake.All of the welding was done with a simple Mig welder.Not sure what material was the muffler made out of.....some people say it's stainless but I don't know because my magnet sticks to it.
I welded both sides of the 3 inch pipe. the key is to cut the pipe in half and little by little shave some material off the edges or cut another 1/4 inch off the piece's you already cut to get a tighter fit.I used a electric grinder with a thin cut off wheel to make the cuts.Hope I did not confuse you guys.
How did you manage to get the right muffler completely out/off the car?
Did you have to loosen and lower the rear-diff cradle a little bit?
thanks buddy
Some people lower the cradle..... I did not, just make sure if your using jack stands, lift the rear nice and high so you can wiggle those bad boys out, also remove the center bolts that hold the sway bar bushings out of the way.... no need to remove just let it hang down
Received 1,335 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'22-'23
To remove the right side muffler: Remove the heat shield above the mufflers, that gives just a little more wiggle room. I would try that before dropping the cradle for sure.
I much prefer using 2 jack stands and a 2x4 under the cradle to lift the back, especially if it is going to be resting high for a while, so not having to drop it would be a big plus.
Your post timing was perfect.
I am doing this and was going crazy to find a good post with good pictures and a good explanation.
Thanks!!!
ErnieO
Thanks!!!
ErnieO
[/B]
[/B]
Who makes a good after market system for the Z06 ? I was looking at SLP Loud Mouth's and Corsa Extreme's but it seems neither are made for our cars.
