C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] ZR1 crate engine installed in a Z06
Old 05-09-2010, 03:54 PM
vette.se
vette.se's Avatar
Default ZR1 crate engine installed in a Z06
If anyone is interested - now it's done, ZR1 engine in a Z06 car. Of course the big question will be WHY ?
Crate engine finaly delivered, DRM did a very good job finding a engine and the needed accessories quickly !
You need not only the engine you can see advertised at around $21000 in many places but you also need the complete accessory drive kit (all pulleys, belts etc), a A/C with 6 rib pulley, ZR1 clutch and slave cylinder, water intercooler, water pump (do not try to use the ZR1 water pump ... dont ask why ) all hoses to the intercooler water lines, power steering cooler, injectors (you can not use the ones that comes with the engine) the final cost is closer to $28000
DRM installed the accessory drive kit and clutch before they shipped it. Thanks
The customer car is a 2008 Z06 that had a QM600 cam, ARH headers and a Callaway Honker installed - 532rwhp.
The problem is that it's not emission legal so that is why he wanted something that is GM stock and passes the yearly emission tests.
Many probably asks themselves why not a A&A kit, twin turbo o similar ... the issue in our country is that it's not legal to put in any kind of power adder in the car (at least not visable at the test station ) All the standard supercharger and turbo kits is very visable but a ZR1 engine is more likely to pass the yearly test. We will take care of the only visable issue which is the text on top of the supercharger saying 'LS9 Supercharged' by installing a thin aluminum piece saying 'LS7 7.0' . Ridiculous - yes but what to do with stupid local laws
The owner did not want his license plate visable in the pictures so why not a Panama plate ...
Almost stock ...
The driveline taken down ...
The ZR1 engine installed ...
The difference between the stock Z06(on the left) and the ZR1 slave
Rick Dadd built this one ...
Car back together again ...
Now we had a lot of work fixing wiring harnesses, vacuum lines, water lines, modify the Callaway Honker intake (heat gun modifying ), installing the heat exchanger and water pump (now we are using a water pump from a Magnuson kit). Modifying the engine oil cooler etc.
And finished ...
We used a Magnuson style hood to clear the ZR1 engine ...
Now we are running a base modified tune in the car until the new engine have been running around 500 miles with nice and easy driving. After the 500miles it will go on the dyno to make the final tune. The engine is a completely stock, the only mods is external with ARH headers and a Callaway honker cold air intake so we will probably see stock numbers + around 30rwhp.
Dyno tune will be made next week and I will post some pictures here + a link to a video on youtube.
Old 05-09-2010, 04:14 PM
tjwong
Support Corvetteforum!
tjwong's Avatar
Nice Job! I guess we are lucky here, well at least in some states. California for one doesn't even allow long tube headers. Technically by federal EPA laws they are totally illegal, however there are many states that don't bother looking, California on the other hand does "look" and will not pass a car equipped with long tube headers. Plus they sniff the cars while many states do not by using a simple scan tool pass or no pass method. Hopefully that won't change in the near future.
Old 05-09-2010, 04:23 PM
40YRW8
40YRW8's Avatar
Very, very cool! If you get a chance, could you weigh the car and let us know? I think it wil be very interesting. Kilograms will be OK Well done.
Gary
Old 05-09-2010, 05:51 PM
90sundevil
90sundevil's Avatar
If GM made the ZR1 motor as an option I would go for it, I could care less about all the CF junk, the brakes and the suspension adjustment.
Old 05-09-2010, 08:36 PM
JT Metal
JT Metal's Avatar
St. Jude Donor '12-'13
Super Duper!!!!!
Old 05-09-2010, 08:53 PM
DSOM Z06
DSOM Z06's Avatar
Wow that's an awful lot of money just to pass yearly inspection. The owner needed some connections at the inspection station or throw around some hundreds, would be much cheaper. Nice job however.
Old 05-09-2010, 09:01 PM
snide
snide's Avatar
CI 4-5-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11
Interesting.
Old 05-09-2010, 10:13 PM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
Sweden is sure tough. My Vette friend in Sweden has to remove his supercharger each year, and this year, they made him cap his cutouts!
All that and a 6 month Corvette driving season....after making freinds with my him, I sure appreciate living in Florida where we don't even have any inspections at all!
Old 05-09-2010, 10:22 PM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
Some serious Vettes at the spring dust off in Sweden this year! Beautiful cars. You Swedes are serious modders, and it's that much more impressive given all the hassles (and super high prices ) you all have to endure!,
Old 05-09-2010, 10:56 PM
vettluver
vettluver's Avatar
Nice job, waiting with baited breath for the dyno numbers and weights.
Old 05-09-2010, 11:14 PM
ranger1
ranger1's Avatar
Very cool, I would do that if I had the money...
Garry
Old 05-10-2010, 12:07 AM
LFZ
LFZ's Avatar
Why not...good job.
Old 05-10-2010, 12:24 AM
0Adam at RSI
Former Vendor
Adam at RSI's Avatar
Super cool!
Old 05-10-2010, 01:31 AM
blaine123
blaine123's Avatar
Nice install, but a bit extreme for emissions. I'd just move for a lot less hassle.
Pretty sure California still has open borders still. Get the F*&^ out while you still can. California is as close to being a Stalinist style Communist ran state as you can get.
If you like cars that would be the last place on earth you would want to be. Not to mention the other Cali malfunctions.. High taxes, fire, earthquakes, high % of tree huggers,....
The county in my state has no inspections or emissions.
Old 05-10-2010, 02:10 AM
Qtr_Z06
Qtr_Z06's Avatar
you swedes are very serious when it comes to modding. I know the swedes where the first to install a superchargeron the GEN 4 vipers ( 8.4) so thats something else.
Old 05-10-2010, 09:53 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Looking good Anders I have the inter cooler pump heading your way today!!!
Randy
Old 05-10-2010, 09:58 AM
BrnEyzR1
BrnEyzR1's Avatar
To ZR1 crate engine installed in a Z06
Old 05-10-2010, 02:50 PM
0Steve@AandACorvette
Former Vendor
Steve@AandACorvette's Avatar
Location: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
Great job Anders!
Old 05-10-2010, 03:59 PM
Sandman93
Sandman93's Avatar
WOW --
But FOR 28K not including install why not just upgrade and get the ZR1???
Old 05-10-2010, 04:22 PM
VetteVinnie
VetteVinnie's Avatar
Received 1,677 Likes on 1,069 Posts
Originally Posted by Sandman93
WOW --
That was my thought. The cost of the upgrade to the Z06 + the cost of the Z06 (new) would be pretty close to the cost of a ZR1, I'd think. Why not just get a ZR1?
Quick Reply: [Z06] ZR1 crate engine installed in a Z06
