C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Aftermarket shifter rattle
Old 05-23-2010, 10:12 AM
cyi1
cyi1's Avatar
2018 C7 of Year Finalist
Default Aftermarket shifter rattle
I purchased my car about a month ago and it has the hurst aftermarket shifter on it. The shift **** rattles in each gear at full throttle. I've been trying to find a fix for this but haven't had much luck. The only thing I was able to find was that a few people who went with the MGW said it didn't rattle at all.
Does anyone have any experience with this shifter and have a quick fix for it? I'll try anything before going back to the stock shifter box.
Old 05-23-2010, 10:55 AM
captej
captej's Avatar
.....mgw
Old 05-23-2010, 11:44 AM
cyi1
cyi1's Avatar
on the posts I've seen, some mgw shifters rattled and some didn't... ill try it out though if i can't find a fix for the hurst
Old 05-23-2010, 12:01 PM
DarkKnightZ
DarkKnightZ's Avatar
My Z06 with the MGW shifter has a slight rattle on initial start but once it's warmed up it almost always goes away. MGW is about 30 minutes from me and the owner even told me I might experience a slight rattle (I had one previously in my 05 LPE coupe). Now this rattle isn't in the shift **** itself though, it's in the actual shifter. MGW's new shift **** is great and is a perfect fit/feel for their shifter.
Old 05-23-2010, 12:11 PM
HornZ
HornZ's Avatar
I have a 2007 Z, and the original shifter "rattled". There was a TBS out and they (GM) replaced the shifter with a newer model in late 2008. That shifter was quiet. Then I got the MGW (NEW model) early last year (2009). I absolutely love it, and would not go back no matter how much noise it made. BUT, it does vibrate/buzz under heavy acceleration when cold. I took it all apart and put in the std C-6 shift box, and that made for some improvement, but it did not go away.
I would love it if there was a QUICK FIX for this, but I have not heard of one yet. Some have used a heavy shift ****, and that solved their problem. I like the stock ****, so I haven't done that. Most of the summer it is just fine, but in the early Spring and late Fall when it is cold outside, it buzzes.
I think it depends on the individual car whether it makes noise or not. Some (mine), must transmit more vibration thru the shift linkage than others. I wish there is some way I could dampen that to reduce the vibration, but it would take someone with more technical knowledge than I posses.
I have been following the MGW shifter issue for a long time, and MOST cars do just fine with the new model and C-6 box.
Good Luck!
Old 05-23-2010, 12:46 PM
AFVETTE
AFVETTE's Avatar
My MGW sounds like a diesel gone bad. I like the feel of the shifter but the noise is driving me nuts.
Tom
Old 05-23-2010, 02:38 PM
Nanook
lifeislikeaboxofchocolats
Support Corvetteforum!
Nanook's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19-'20- '21-'22-'23-'24
I have not been successful in getting rid of the rattle in mine.
I have the lastest MGW shifter, new std C6 shifter assembly which replaces the Z06 assembly, and a Leopard heavy shifter **** and it still rattles under hard acceleration.
It seems temperature has a direct effect as the intensity of the rattle diminishes with heat.
Always open to suggestions ?
Old 05-23-2010, 03:58 PM
Balducci70
Balducci70's Avatar
Tom
mine too. must say when first put in it was not that bad just had motor out when i got it back i was like f--- it rattles bad .must talk to the docs this week .
Old 05-23-2010, 04:36 PM
ronsc1985
ronsc1985's Avatar
My experience with the MGW shifter is as follows.
Stock shifter never rattled in my 2008.
Installed MGW shifter, new design, and a C6 shifter box in the summer. No rattles. As soon as the temperature went below 55 F plenty of rattles.
Removed MGW shifter, reinstalled stock shifter, no rattles at any temperature including last winter at 15 F.
Sold MGW shifter. End of story.
Old 05-23-2010, 04:41 PM
AFVETTE
AFVETTE's Avatar
I could hear it inside my helmet going WOT when I attended a HSDE at Road America last month. It's unnerving considering all the talk of LS7 blowing up when pushed hard on race tracks.
I'm considering going back to stock.
Tom
Old 05-23-2010, 05:41 PM
Luweegy
Luweegy's Avatar
Tom
The MGW is noisy as hell.Their answer was buy there upgraded one, I thought mine was? Or buy a C6 shifter and box for 135.00.It amazes me the products people sell us that aren't rt and want us to spend more $ to make them rt.The Shifter works perfect.But the noise sucks. The C6 box didn't work either.
Old 05-24-2010, 12:56 PM
goatts
goatts's Avatar
The only thing I know of is take it apart and pack it with synthetic grease. I did this with my B&M and it kept it from rattling for a while.
Old 05-24-2010, 01:16 PM
DSOM Z06
DSOM Z06's Avatar
My Callaway STS only rattles when I keep my hand on the shift ****. As soon as I let go it stops making noise.....weird.
Old 05-24-2010, 02:20 PM
jamsvet
jamsvet's Avatar
Used to miss shifts prior to the installation of an MGW. My priority is no missed shifts. If you're posing on the street, stay with the stock shifter. If it matters, ie. on the track, go with MGW.
I really don't care if it rattles. It's only under acceleration and it's a "race car with a radio" anyway.
As to customer service, I've received better customer service from George than from GM.
Old 05-24-2010, 02:27 PM
Nanook
Nanook's Avatar
George is outstanding !
Old 05-24-2010, 03:20 PM
fly a Z06
fly a Z06's Avatar
RPM Motors in Santa Clarita installed a C5 threaded Hurst **** after they cut 1/2" off and threaded my 07Z's stock shift rod. If your Z was bought used maybe it has one of the Hurst ***** that Pipedreams sold with an insert to fit on a stock unthreaded shift rod causing it to rattle.
Happily mine never rattles.
Joel
Old 05-28-2010, 10:03 PM
MD1677
MD1677's Avatar
I have had this problem as well and just found a great fix! I purchased some 3/8 tube foam that is designed to wrap around your water pipes and cut a piece and placed it around the shifter between the **** and the base and taped it tight with electrical tape. Absolutely no rattle or noise now!!! Try it!
Old 05-31-2010, 02:32 PM
3 Z06ZR1
3 Z06ZR1's Avatar
Check my post for the dreaded rattle on the Z's and how I got rid of it.
The Hurst is great shifter. MGW can't be any better. It just the noise.
The Hurst shifts short and quick!
To Aftermarket shifter rattle
Quick Reply: [Z06] Aftermarket shifter rattle
