Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake How-Tos
- How to Remove/Replace Front Brake Pads
Step by step instructions for do-it-yourselfers.
- How to Replace Rear Brake Pads
- How to Replace Front Brake Calipers
- How to Replace Rear Brake Calipers
- How to Replace Brake Disc
[Z06] DIY: Changing brake pads on stock calipers + Removing rotors
#121
Now I run one piece pads so don't mess with the pins.
Brian71 (05-07-2017)
#122
Sometimes heat helps them come out. I also have found if I have one stuck that I try to loosen it when I come off the track with hot calipers, that usually works. If I have one that frequently loosens up, I'll tighten it when I come off the track.
It worked for all the pins except for one. It just wouldn't budge. Even my mechanic had a crack at it. It's siezed and it aint coming out. It was one of the rear caliper pins on the inside.
